Page 7 of 18 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 270
Thread: MRP 7age/9age 1900cc Stroker Kit
  1. #91
    Jul 2008
    Auckland
    Default Re: 7age/9age 1900cc Group Buy!
    Adding them is a benefit. For those who dont want to go through the hassle of adding in the squirters. May not be as good as oil squirters but its something!
    Having them along with the oil squirters will just aid more oil cooling and there isnt going to be any negative with them there.
    Now 9AGTE 410kw atw
  2. #92
    Bazda, i realise it's not an easy answer to quantify and there's a lot of 'depends on' in it, but given the tight timeframe i've left myself to make a call on this, what revs would you recommend limiting it too if going NA? Longevity is obviously a variable; let's say i'm looking to not make it explode for a few years of track days. I noted your earlier comment about 'easily/at least 9000rpm', but was there some conservative-ness there allowing for big boosted engines, and Vito in general?
    Interested on input from anyone else too; am currently trying to pull together a spec and am starting with the limits of this bottom end and working back from there to see what is achievable, or required to get the most from it. ie if i'm not looking past 9000rpm, cams, comp ratio and valve size need to remain moderate.
    Similar question on the 82mm vs 82.5mm; i know it's an old discussion around the web and like above am doing research and reading, will just appreciate people's thoughts. Nick Parker, i'm assuming by the image above of a 82.5mm 16V piston with Atlantic valve cutouts that's you running them? With an SC14?
    I do realise how general and difficult to answer these questions are!
    Toymods Club Member
  3. #93
    Convictania
    I love you.
  4. #94
    Feb 2010
    Auckland
    here's my point of view (not that it's worth the binary code it's written in.. or hex)
    Spool advertise their kit as 10,000rpm / 1000hp capable (no mention of how long for tho lol) and in my mind Bazda's kit has some superior design elements, that is why he's gone to so much trouble after all.(thanks Baz) So with direct comparrison you'd say similar claims could be made. But i'm sure there is a more technical way to quantify potential performance than comparing it to someone elses marketing campain. (not saying spool is b/s)
    With the right supporting mods,block prep, head work, balance, main studs, l/w flywheel, race bearings etc... and a little mechanical sympathy and regular servicing I see no reason it shouldn't last the distance, but limiting it to 9krpm might make it last longer?.
    If I were doing N/A, i'd be looking to keep the bore size around 81.5mm. purely to preserve a bit more cylinder wall strength, and to allow a rebore and/or swap to turbo pistons in the future should something like a dropped injector or bad tune/gas grenade the motor, or more power was needed. I'd limit myself to 9-9500rpm, not due to reliability, but more due to cost, as things like dry sumps, massive cams (288+), and other supporting hardware ain't cheap as you probably know. but hey if you can spare the cash I'd love to see the results
    Hope you find the info/advise you need.
    no doubt Bazda will be able to advise on a more experienced/technical basis. Tho I believe he's heading o/seas very soon so he might be unavailable.
  5. #95
    Jul 2007
    get some piston speed calculators out, and keep the revs to a number that isnt approaching formula 1 levels of piston speed and you should be right, how about that?
  6. #96
    Oct 2009
    Keep in mind that your going to have two overhead camshafts spinning at 4500rpm along with all the valvetrain gear, flywheel, crank pulley, alternator pulley, water pump pulley, clutch disk, pressure plate and input shaft..........
    I would of thought that the valvetrain would be the limiting factor here
  7. #97
    Jul 2007
    nope. valvetrain (with the right mods) is good to over 11,000rpm in the formula atlantic engines. bottom end will be limited well before that i would think..
  8. #98
    Oct 2009
    The amount of money required to build a 11,000rpm head that flows enough air at those RPM's would far exceed what this kit costs...... The time on a flowbench alone wouldnt be cheap.
    So realistically, as in money wise, your going to be limited to 9000rpm tops I would imagine?
  9. #99
    Jul 2007
    not really. 2-3k will get you a head built to rev to 10,000rpm. i know because i have a friend with such a head on their engine...
  10. #100
    Oct 2009
    FACTORY20v Blacktop heads will flow 700hp (only issue is valve springs are to soft for high boost) according to Kelford cams headwork will increase your VE and how it flows main reason to do head work is to help the turbo spool faster (in FI applications) not because it needs to flow more but it doesnt hurt to port match, oversized valves, stronger springs, 5 cut regrind and polish the hell out of it
  11. #101
    Feb 2010
    Auckland
    $1000 for this as a good starting point.
    http://www.toymods.org.au/forums/eng...alves-cnc.html
    Add in some big cams with matching springs and I think you'll be listening to Kenny Loggins every time you pop out for milk
    That said.. 2-3k would get you a nice turbo setup, would it not?
  12. #102
    Jul 2008
    Auckland
    The kit will rev to 10k with no issues if you want it to. It really depends on all the supporting mods you undertake.
    ie. main cap supports, dry sump, light weight flywheel setup, very good harmonic balancer on the front, valve train setup etc, well balanced internals.
    Now 9AGTE 410kw atw
  13. #103
    Oct 2009
    Does anyone make a very good harmonic balancer for the A series engines?
  14. #104
    Jul 2008
    Auckland
    Quote Originally Posted by shrike View Post
    I know Ross make them but they are not cheap at all. Around the $500AUD mark.
    I am getting in contact with ATI is the USA to see if they can make a run of them.
    Now 9AGTE 410kw atw
  15. #105
    loves hi RPMS Backyard Mechanic
    yes i do.
    yeah it was around that price, and head will definately rev to 10000rpm (engine probably will too, but i keep at a much more reasonable 9500rpm)
    Quote Originally Posted by Stolic View Post
    i pretty much do every time i drive the car...
    i didnt want a turbo set up. my cars not about big power, its more about usable power, balance grip and being an obnoxious arse with open trumpets at stupid RPM.
    while i cant afford said kit now, ill will be watching for another group buy to get my hands on this awesomness.
    N/A for life...
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 9age??
    By Bazooka in forum Tech and Conversions
    Last Post: 06-10-2012, 08:44 PM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
