Much more usable ,workable , Livable set of rod to stroke ratios are in the range of 1.85 down to 1.65 , higher ratios should be reserved for engines that operate at Consistently higher average engine speeds . while the lower ratios work best and are happier at lower engine speeds , and also when the engine must be strong through a broad speed range , the faster the piston velocities are across the top and bottom dead centres , the most significant DE-SENSITIZING effect upon valve timming ,because the effective valve opening and closing points fall within the the range of faster piston velocities,So giving a mothering a effect by being more tolerant and more forgiving to errors in the effective valve timming and hole in the gearbox ratios , A increase in Stroke is also a better De-sensitizer to valve timming than a increase in Piston Size if your going to increase your Displacement,
