high or low torque is controlled by the cam primarily.
rod ratio affects friction losses, and prodction of torque due to better angle of piston pushing on rod, and lower cylinder wall losses.
are you sure on these??This means the engine will suck harder, and consequently have good low-midrange torque. Larger cams and bigger diameter runners can be used with fewer negative effects
Due to high velocity away from TDC, the maximum cylinder pressure is delayed.
Good for forced induction, detonation resistance etc.
Less homogeneous air/fuel mixtures at low rpm
Comparibly crap low-midrange torque due to lower gas velocities.
Also means that the engine has poorer fuel economy and emissions
the main thing... is that when peak cylinder pressure is reached, the piston is pushing more down than sideways (relative to short rod).
and there is longer dwell, so that more pressure pushes down on piston for longer.
both = more torque.
the timing of peak pressure depends on design... not just rod/stroke ratio, many things..
saying rod stroke ratio greatly afects gas velocity, or air/fuel homogeneity, or emissions... thats reaching a bit perhaps....
just my drunken 2 yen![]()
