Results 1 to 15 of 18
Thread: 4AGE Oil pumps and compatability
    Jan 2007
    queensland
    Default 4AGE Oil pumps and compatability
    hey guys,
    have an AE93 SX, factory 100kw smallport, completley stock..
    the oil pump, around the front main seal area has been horribly damaged from some idiot trying to lever off the belt gear with lever bars...
    unlike me who spent 5 mins drilling and tapping some M6x1mm holes in it and puling it off..
    thats besides the point.. i have 2 options,
    1 - pull the oil pump housing off, set it up in the mill and recut the seal seat as the leverl bars have bent alot of material down, closing up the face... perhaps having to get a bigger seal, or bore it O/S and press a sleve in bore to the correct ID... get gaskets etc.. assemble..
    2 - AISIN Engine Oil Pump OPT-034 Toyota Celica ST Corolla 1.8L | eBay
    or
    AISIN Engine Oil Pump OPT-031 Toyota Corolla 1.6L '85-'87 | eBay
    ofcourse the new pump sounds like the easy option... but as far as i can tell the OPT-034 if for a 7afe, and the OPT-031 is for a bigport, 3 rib block...
    as mine is the 'bigger' oil pump for the 7 rib, with oil squirters.... would there be any i'll effect to fitting one of these pumps?? the engine will most likley stay stock, aside from basic breathing mods... i won't be punting it around the track etc... it's just a daily..
    i just don't want oil leaks!
    oregon
    Default Re: 4AGE Oil pumps and compatability
    15100-19036 - the right pump, from the right materials
    Jan 2007
    queensland
    but toyota pumps are made by AISIN...
    $299.85 my price through toyota.... for the 'toyota stamped' AISIN pump... hence why i was trying to get the direct AISIN pump for 1/3 the price...
    30% of AISIN is owned by toyota... etc etc... history right back to it's foundings...
    Jan 2007
    queensland
    Jul 2007
    can get pumps from lithia toyota for under $200 delivered.
    Oct 2009
    Just stick a aftermarket one in, they are not that shitty and I cant see a stock 4AGE breaking one?
    Jul 2007
    depends how hard you rev em... seen plenty tgp pumps in cars happily revving to 9500 all day every day though....
    Oct 2009
    Yeah the TGP ones are pretty damn good but for a bone stock 4AGE in a daily, man, I would just be going down to Bursons and buying one for $80.
    Probably not as good but oil pumps are pretty simple and most aftermarket gear is not that bad in all honesty.
    Chiba
    If the impeller gears are good (The engine manual has the allowable tolerances) in your Toyota unit, why not just stick them into the after market housing?
    Jan 2007
    queensland
    i ended up buying an AISIN pump (aka toyota genuine) $120 with the 2 gaskets and front main..
    although i will probly go to the bearing shop next door and get a NOK seal # AH83381 (aka toyota genuine main seal) for a couple of dollars, vs paying $18 for the NOK seal in a toyota bag..
    Jan 2007
    queensland
    pump arrived the other day, just incase anyone was wondering.. they are the real deal.. pretty funny how they can't actually sell stuff with Toyota printed on there..
    Not to mention the toyota 10 digit part number printed on the sticker, in much smaller font than the AISIN part number..
    teq Grease Monkey
    California
    Check the gear inside the housing to make sure you got the good version. Google my username + oil pump and you should find a thread on club4ag or hachiroku.net that has the measurements and gear design.
    Andrew
    I've had a few of the different pumps early/late. The photo's on ebay of the rear of the pump look like the later type wave pump (oil squirter type).
    A photo of the back would be good but the innards would be great.
    Very tempted to get one for my rebuild, have primed and fitted a silvertop pump but just not sure on a new pump or not.
    oregon
    Quote Originally Posted by assassin10000 View Post
    Andrew
    Jan 2007
    queensland
    i'll take it apart on the weekend, i was doing some light reading on toyoDIY - confirmed that every pump from AE86 4A/4AC right through to smallport 4AGE/GZE had the same oil pressure releif spring, and valve part number. that was my main concern... as mentioned this is just a stocker.. and won't see any more than normal road use, with the info on Bill's 4A website it would seem that any pump is acceptable, and more than enough for any stock encarnation of 4A, only when pushed into serious RPM are the 'smaller' ones an issue..
  1. aw11 afm compatability
    By MBCorolla in forum Tech and Conversions
    Last Post: 30-12-2016, 05:24 AM
  2. 1g-gte & 1g-fe parts compatability
    By kerzysgotasupra in forum Tech and Conversions
    Last Post: 14-02-2012, 07:40 PM
  3. 7M & 1JZ/2JZ flywheel compatability ???????
    By bbaacchhyy in forum Tech and Conversions
    Last Post: 24-10-2008, 04:29 PM
  4. 4age oil pumps
    By bigstickerperformance in forum Tech and Conversions
    Last Post: 14-04-2008, 09:45 AM
