It has been answered aon another forum.
7M has 6 bolts and 1J/2J has 8 bolts
Any one wanna buy it ?????
I have a Steel flywheel/puck clutch and TRD PP combo for sale and I was informed that it suited a 7M/R154 combo.
As I now no longer need at and am selling it, I have been asked will it fit a 1JZ-GTE/R154 oand I presume that the 2J is the same ?
So the $64 question is :
Will a Flywheel/Cutch and PP combo for a 7M-GTE/R154 be equally home behind a 1J/2J and R154 ?
Anyone know ?
Michael B
'84 MA61 with 7M-GTE
Now 5sp, 5 stud,17x8" Ray's, big assed brakes and decent IC
Better turbo in the wings as well as MAFT !!!!
it might be possible that the clutch itself will fit up to a jz/r154. it is true for w58 boxes
the flywheel definitely wont though
../delete/ban
tech moderator
Yes, the clutch will work on a 1JZ or 7M flywheel (assuming both have an R154).
Norbie!
www.norbie.net
Ah man, i read about this on the celicasupra forums last night but can't find the thread again. From memory all you need to do is drill new holes in the flywheel to be able to mount it to the 1/2JZ and its all fine, well thats what someone said anyways. Not too sure on the 'dodginess factor' though.
vote [1] retarded idea of the weekOriginally Posted by Negative Boost
../delete/ban
tech moderator
2nd'd.....
3rded
thats a (much) worse idea than re-drilling wheels, its even worse than filing out holes or hammering in the wheel studs
Thanks for the replies guys.
Michael B
aages old, and i'm sure i'm quite retarded etc for posting here... but how reatrded is retarded?? as in is it going to fly off and cut your leg off if you redrill the holes?
Its spinning at 5000+rpm. They can and DO explode.
hence the reason for scatter shields, yes it is possible for it to slice through not only your car but your legs as well....
pretty muchOriginally Posted by Mr.mx23
nice question there from the engineer...
