guys thanks for all your help so far, rep has been given out where i can,
Using "Start ya bastard" i can get the engine to kick over for a split second. Also from listening to a screw driver on the injectors it sounds as though they are not firing, as there is defininatly not a continued clicking sound. however, after a few unsucsessful attempts at kicking it over the spark plugs are wet, could they be malfunctioning? I replaced the filters in the backs on them along with the o-rings and what not, although i thought i had done it fine I've had one blow up, and the others don't appear to be working correctly.. Perhaps i've stuffed them up.
Alternatively I guess they could be incorrectly setup in the EMS software.
edit - injectors were listened to while the fuel pump was disconnected, would the lack of fuel pressure effect their operation?
edit 2 - reading here,
http://www.asashop.org/autoinc/june98/techtotech.htm i'm thinking it might, i'll connect up the fuel pump and give it another whirl.'
and finally, edit 3 - no diference, though there is definatly an injector click when the key drops back from AM1 to AM2
