Originally Posted by
kemicalx
Well time for an update,
I’ve replaced the bung injector, know i have spark and still can't get it to actually kick over, I'm presuming it is a timing issue now, as regardless of sensor readings i would have thought if there’s fuel being sprayed in, and a spark being fired at the right time the engine would at the very least try and "broom broom" kick over instead of just whining on the starter motor.
Would it be likely i have to do any adjustment to the CPS? Like twisting the position of sync wheel? As a bloke on the EMS forums said:
Check the timing of the pickups in regard to TDC.
sync must be positioned between the last tooth on the trigger wheel and the first for TDC on number one cylinder.
I noticed when you realign the 7m CPS and then insert it with the engine at TDC, the previously aligned sync tooth gets turned away from its sensor. So perhaps this is the problem?
