Page 3 of 8 FirstFirst 12345 ... LastLast
Results 31 to 45 of 120
Thread: 300RWKW 4AGTE Turbocharger Selection
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    Default Re: 300RWKW 4AGTE Turbocharger Selection
    have you looked at what turbo 30psi4AGTE and the others with 300rwkw 4A's are running?
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    depends if you are talkign VE with respect to the displacement, or the displacement X the intake pressure.
    the former will go over 100% (or there is no point having a turbo...)
    the latter will typically stay similar to what it was for NA, and go down a bit at higher intake pressures..
    what about IHI turbos? any decent pressure ratios there?
    Quote Originally Posted by oldcorollas View Post
    I be talking about VE with respect to the displacement because it seems to be the relevant figure to use in the turbo size calculations. It is the only way to make my own two engines data fit the calculations.
    Besides talking about the VE which makes your engine well over 100% VE is much more fun!!!
    Jason
    Forum Contributor Domestic Engineer
    Yeah, I've found the same too. According to most calculators, my dirty (basically bolt on only) 7M has a VE over 100 in the mid ranges when making the least postive guess for the BSFC when looking at power vs rpm and boost. It only gets higher if the BSFC numbers are more 'normal'.
    I think the calculators tend to estimate for factory engines with dodgy 10:1 AFR tuning and 3/5ths of bugger all ignition advance when under boost.
    I would have thought that for 300RWKW (around 460 maybe 480 engine HP), you'd need closer to 50 lb/min??
    MA71 - 7MGTE - 340RWHP
    VAASA / FINLAND
    Holset HX35 Super. they have seen going 500+ engine hp, maybe up to 400+ RWHP in 4AGE. i will recommend that one, they are strong, "Cheap" very popular in Finland ! i think Most popular because over here we got own Modell series... Turbos are assembled (most of them) at Finnish Turbo import company and got full support from Holset main factory. but they are "HUGE"
    i do not sell them, this is well known re-sell company of those turbos in Finland.
    http://www.kkdmotorsport.com/kuvat/H...ine-up-KKD.jpg
    http://www.kkdmotorsport.com/yhteystiedot.php
    they will ship Worldwide. And Support English
    first hit at Youtube..... http://www.youtube.com/watch?v=iSazXwuo2Tk
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    oregon
    Recommend you read up on this(contact the poster) - http://forums.club4ag.com/zerothread?id=1638 - he's been pushing well over 300whp for a number of years now.
    You may also find this useful - your 4AGE Turbo Setups and the Numbers - http://forums.club4ag.com/zerothread?id=34252
    Convictania
    Quote Originally Posted by MRMOPARMAN View Post
    ^^ This is a good point, Bazda also springs to mind.
    edit: just realised Bazda might be running a 7a bottom end, I can't recall off the top of my head.
  8. #38
    Jul 2007
    Yep bazda is 7a bottom end. and 30psi 4agte is a fairly different setup to mine. I have of course looked at what turbos others making this kind of power are using. But a lot are either different engine configs or are used for drags, or are street cars that were built with just a HP figure in mind and no attention to how suitable the setup would be for track work etc etc.
    Besides I am trying to make an informed decision by analysing compressor plots and wheel sizes etc rather than just blindly picking whatever everyone else is using.
    Also, looking into it a bit more, that holset is way too big to be useful imo.
  9. #39
    Jul 2008
    Auckland
    No matter what you do, the power you want (300kw atw) its going to be laggy.
    Esp trying to run a stock 16v head...
    Blacktop head can happily push out 270kw atw on 22psi using a TO4E 60 Trim (with twinscroll exhaust). Full boost at 5k (22psi).
    Im vouching on the Turbonetics GTK series. They are meant to have a wider comp map than their other turbos.
    + They look sexy! and we can do them at a very very good price.
    We got many guys here running GT3076R on their 4agtes and 7agte. They are all pretty laggy maing full boost at 5k on the 7a and 5.5-6K on the 4a.
    I've put most of them onto the T04E 50 trim and they have gained alot more mid range power making the car more usable on the street.
    Now 9AGTE 410kw atw
  10. #40
    Jul 2007
    i know its going to be laggy. but that doesnt mean i cant try and minimise lag. otherwise i would just go get a GT35R.... GT3071R looks like it will give me enough power (maybe not 300rwkw, but close enough to be good enough) whilst still giving reasonable power at around the 4.5k mark.
    head will have kelford turbo cams, but otherwise will be a stock smallport head yes.
    get maps for the GTKs and if they look the goods then we will talk, baz.
  11. #41
    from that image..
    HX35
    The standard set-up, this charger can offer performance for up to 500hp
    It's built to be easily adapted to motorcycles
  12. #42
    VAASA / FINLAND
    quite big but have seen HX40 in bikes also
    - IQ 1.0 -09
    - Lexus IS250 -06
  13. #43
    oregon
    If I may......
    dump the stock head
    If you want to make power easily... its time to think of O/S valves, and a full port job. Why make your turbo work harder...
    Here are 3 smallport intake ports.... stock, one I ported(std valves), and finally a head ported for O/S valves.
    Note how the O/S valve port has been pushed all the way out to encompass the normal bevel @ the manifold flange. Also note how both my porting, and the O/S valve porting have "opened" the port roof, and port sides to fully expose the bowl to the port - example of opened port roof and sides below
    Now the exhaust side.... again stock, followed by ported std valve, and finally ported for O/S valves
    One last STRONG recommendation... de-shroud the chambers - you don't want any ping @ 300 kw
  14. #44
    Jul 2007
    cash spent vs benefit gained.... do you have any quantifiable results between your ported head and a stock head?
  15. #45
    Hey mate,
    The benefit of a ported head with O/S valves is similar to the benefit to your multivalve head vs my 2 valve head in the first place...
    With decent porting and oversize valves my 2 valve head would make the same power with less boost i.e. more efficient as the turbo can move the required amount of air with less resistance.
    Already you can make - call it the same - power as me with less cubic inches of motor and 5psi less boost. If done properly you can only go forward with oldskewls advice!
    Jason
  1. couldnt reach 300rwkw
    By petespipes in forum Tech and Conversions
    Last Post: 17-09-2007, 05:46 PM
  2. Turbo selection 4agte
    By TooF in forum Tech and Conversions
    Last Post: 14-09-2007, 08:18 PM
  3. 300rwkw on 2j with factory twins
    By allmtr in forum Tech and Conversions
    Last Post: 21-03-2007, 12:06 PM
