Was going to suggest phoenixtuning. I bought stuff from them before.
If you have the part number you can get them from Amayama.
Locally though, I don't know of anywhere.
Does anyone know where I can get Toyota Electrical Terminals for a BT 20V O2 Sensor Connector?
I ordered a 4W 02 Sensor for the AE111 from the States (1/2 price of OEM); it was a Denso 234-9011 which I was advised was a direct fit but the harness is ~ 500mm long Vs ~ 120mm for the Toyota part (Connector on harness is also incorrect).
I can use it as is but it would be quite untidy*; I will have to loop it upwards & zip-tie it against firewall; so to avoid this would obviously like to cut harness to size and crimp on new terminals (R/R old / new connector etc) but (no surprise) you can't buy them (new terminals) from Toyota nor do Auto-electricians have access to them.
* As far as I know, you cannot / should not cut & splice O2 Sensor wires.
Found a place in the US < Tweak'd Performance: We specialize in Toyota Engine Swaps & Wiring Harness Conversions - located in Summerville, SC > that might have them but wanted to see if I can get them locally or direct from Japan. . .
Can anyone help?
Thanks. As someone quite rightly pointed out I should have posted this in the Tech section so I'm going to move it there.
