Results 1 to 8 of 8
Thread: Toyota Electrical Connector Part Numbers + Connector / Circuit Cross Reference
    Jan 2007
    Default Toyota Electrical Connector Part Numbers + Connector / Circuit Cross Reference
    Picking up the C56+LSD swap into the AE92 I of course forgot to ask for the female connector + x mm of lead wire to the Starter Terminal < and other Terminals on the G/Box casing> . It can be a real PITA chasing down connectors as everyone knows.
    Being a pretty Obs / Compulsive kind of guy I just had to do this with OEM connectors; luckily, after some rummaging around I found the following Sites;
    http://www.ih8mud.com/tech/WireHarnessRepairParts.php
    I also found a cool Connector / Circuit reference for the 20V Engine Harness. Because of the Standardised nature of these plugs this will be useful to owners of other models as well. (i.e. 4-wire O2 Sensor Plugs when upgrading from 1-wire Sensors)
    http://padandwheels.com/mr2/blacktop...ngharness.html
    PS: Because I've obv got too much time on my hands right now I also wanted to just buy the Battery > Starter Wire + Rubber Terminal Cap for the AE111 to save me having to get one made up / chasing up a Cap - I'm sure there's a Part number for them both but can't be sure because the ToyoDIY drawings aren't up to the job - taking a guess I think it may be Wire = Wire 3 / 82123-12290 & Cap = ???
    If anyone can confirm these part numbers it would be a great help.
    Chiba
    Default Re: Toyota Electrical Connector Part Numbers + Connector / Circuit Cross Reference
    Can you provide a link to the toyodiy page you're looking at?
    Also, if anyone can provide a source for the rubber bungs used to seal the hole around where the engine harness goes through the firewall into the cabin, you will be instantly granted god-level status.
    TERRA, these are not OEM style ones, but I have used these before, http://www.sealsit.com/firewall.asp
    Chiba
    Hmmm, they could actually do the job. Thanks for that, and +rep.
    If anyone has a supplier for OEM style grommets, let me know, but these could get me by.
    Jan 2007
    Can't sleep and I'm on this Forum. . . Sad really.
    1. http://www.toyodiy.com/parts/p_J_199...CFZF_8202.html
    2. Do you mean the wierd accordion Type bungs?
    Chiba
    I have an AE101 Levin (I used the relevant pic from Toyodiy). The bit I'm after is highlighted in red.
    Administrator Backyard Mechanic
    Jul 2009
    Can you buy them? i've had a few dealers searching for plugs and they all have said sorry i can supply you a loom, but not the plugs. I even emailed the .pdf files you found and they said sorry can't help.
    maybe it was all too hard.
    however... www.phoenixtuning.com was able to help me out with some stuff i needed.
    Jan 2007
  1. Replies: 19
    Last Post: 27-05-2008, 10:45 PM
  2. MAF connector pin out
    By amichie in forum Tech and Conversions
    Last Post: 20-03-2008, 07:39 PM
  3. Connector Parts Numbers
    Last Post: 21-08-2007, 07:08 AM
  4. Fan consant run connector
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 31-05-2006, 04:55 PM
