Results 1 to 3 of 3
Thread: Fuel reg adapter for 20v
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default Fuel reg adapter for 20v
    I may remove the stock fuel regulater on my 4A-GE 20v for a guard mounted adjustable type.
    Is the adapter I need the same as all other Toyotas like 2JZ and 4E? Or maybe it's the same as Subaru or Mazda?
    May 2006
    Default Re: Fuel reg adapter for 20v
    If your planning to put up the fuel pressure you can retain your stock reg. The second reg acts as the restriction point.
    Tasmania
    I am guessing the adapter is the same as other Toyotas such as 4E-FE and 2JZ-GE, and the same as some Subaru. Main hole is 11mm, distance between small holes is 39mm. SARD SRA02. (SARD SRA06 should work also)
  1. W5X-R154 adapter
    By The Real Roadrunner in forum Tech and Conversions
    Last Post: 02-11-2011, 09:06 AM
  2. Help needed for 2JZ stock fuel rail adapter
    By Hengsta in forum Tech and Conversions
    Last Post: 21-10-2010, 08:46 PM
  3. adapter for rev gauge
    By rshuwy in forum Tech and Conversions
    Last Post: 06-08-2009, 04:06 PM
  4. jap fuel neck reducer/adapter/cap thingy....
    Last Post: 30-11-2005, 04:06 PM
