Results 1 to 7 of 7
Thread: Help needed for 2JZ stock fuel rail adapter
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Default Help needed for 2JZ stock fuel rail adapter
    Howdy lads, I need some help (pictures) with the adapter plate for the stock 2jzgte fuel rail to use for a fuel pressure regulator.
    Any pics and info would be greatly appreciated
    Reason I ask is there's not much room there when the throttle is all the way down.
    Thanks, Heng
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    May 2007
    Default Re: Help needed for 2JZ stock fuel rail adapter
    just had one of these put on the missus car...
    will see if i can get some pics tonight if i remember
    Anyone?
    Wilbo?
    May 2007
    grabbed some pics last night... will upload when i get a chance
    May 2007
    ok so not the greatest pics but you will probably get the idea from it...
    some sort of fancy annodised fitting with a 90* brass barb fitting to pipe... reasonably tight but not fouling on anything...
    hopefully of some use for u
    I drilled and tapped mine to M12 x 1.25 (The hole is 11mm if I recall), which worked well...
    On my first setup I used a Banjo bolt and and associated fitting recycled from a different OEM fuel system to the FPR (I'd happily do this again)
    Playing with the fuel system later I've ended up with a 90deg speedflow -> pushloc fitting, but the clearance is pretty tight...
    Wilbo's JZA80
    Wilbo's JZZ12
    Cheers lads,
    I thought about that brass one but I didn't know when the thread will stop as I wanted it at a certain angle point but I see yours is pointing to the front of the engine (I can deal when the extra lenth of hose) buy I wanted it angled to the back of the engine.
    Banjo bolt is the other one I only thought about today I'm gonna go tomorrow and see if I can get banjo at pirtek or enzed.
    Cheers guys much appreciates
  1. 1JZ fuel rail w/ big injectors
    By andyjz in forum Tech and Conversions
    Last Post: 12-10-2009, 04:28 PM
  2. Custom Fuel Rail Fabrication
    By medwin46 in forum Tech and Conversions
    Last Post: 22-12-2007, 08:09 AM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  4. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  5. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
