Results 16 to 21 of 21
Thread: 18rgeu from airflow to map sensor
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default Re: 18rgeu from airflow to map sensor
    won't work - at WoT at low revs, you get/need low air flow, whereas at high revs you get high air flow- even tho the throttle (in your case linked to the pedal) is in the same place.
    Get a cheap 2nd-hand Microleb or Megasquirt or other low-end ECU. I'd suggest the megasquirt as there are folks who have done this engine and the user community shares configurations. You can use the existing dizzi and trigger wheel, and also the stock coolant temp sensor. Air-temp sensor can come from any toyota that has a separate IAT sensor in the airbox (or simply grab the coolant and air temp sensors from a V6 commode).
    Can you tell me which model to look for?
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    I only know the Megasquirt hardware - do you feel like building a kit (e.g. handy with a soldering iron) or would you prefer something you just wire up, tune and do epic dirt skids with?
    Casino nsw
    Kits are ok for me and theres quite a few second hand ones out there but i dont know which models will work for me.
    02 TS50 falcon
    This: http://www.diyautotune.com/catalog/m...ase-p-119.html
    Then install MS Extra 2 firmware. Use the ITB's TPS. Pinch the air-temp sensor from a v6 commode (back of intake manifold) and a bosch coolant temp sensor (2 pin, not the 1 pin gauge sensor).
    Even tho you race it, a wideband kit LC1 (or a kit from 14point7.com unit if you feel brave) will help you sorting out the tune.
    Several folks here have got 18RGs on Megasquirt ECUs - they might be willing to share. Tho being ITB, I would suggest some dyno time to get the fuel maps and the accel settings suitable for race work.
    Wgtn
    Quote Originally Posted by e30-323ti View Post
    Universal AirFlow Converter looks like it could do what you need assuming the AFM & MAP sensor have the same 5v range, will still take some 'tuning' to get it right (which obviously has it's own dangers).
    Quote Originally Posted by dale30 View Post
    had a quick look..does that replace the afm??
    No, you replace the AFM with a MAP sensor (both are a 0-5v output), then use the UAFC to 'tune' the voltage output back to the ecu.
    If changing to a MAP sensor on ITB's you will probably need to link all intlets (post TB) to a common canister/pulsation dampener to get a clean MAP signal.
    Other option is do as suggested, and create a plenum and retain an AFM, but use a larger AFM (eg. a bosch flap type one from a 3.5l BMW), but would still need tuning with the likes of the UAFC, but may be just a overall reduction based on the increase of cross section area in the AFM. Or even go to a hotwire type AFM eg. Nissan.
    These may give a better result than a change to a MAP sensor on an AFM based ecu, and if you have big cams etc...
    I can sell you my fully assembled Megasquirt 2 ECU if you like. I am looking to move up to the Megasquirt 3 as it has some features which would be beneficial to my 18R-GTE.
    Let me know. I also have the wiring loom and serial programming cable for it.
  1. oxy sensor for 18rgeu
    By airfireman1 in forum Tech and Conversions
    Last Post: 24-06-2007, 05:01 PM
  2. airflow to map sensor
    By damo101 in forum Tech and Conversions
    Last Post: 31-08-2006, 09:03 PM
  3. 18rgeu airflow meter swap?
    By iflylo in forum Tech and Conversions
    Last Post: 07-02-2006, 11:22 AM
