Results 1 to 4 of 4
Thread: airflow to map sensor
    Aug 2006
    success 6164
    Default airflow to map sensor
    i recently blew my 88kw 4age up in my ae82..
    i was considering a full rebuild but i can get another engine real cheap..the only problem is that it is airflow metered instead of MAP sensored.
    would it be possible to change the manifolds over so i can have the map sensor instead of the airflow meter.
    both of the engines have TVIS aswell.
    any help would be greatly appreciated..
    damo
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Default Re: airflow to map sensor
    To run a map sensor it is not necessary to swap manifolds, just plumb MAP snesor line into the intake mainfold after the throttle body, don't share a manifold port with another vacumn line.
    regards
    jon
    Perth WA
    I assume you've sourced an AE11 4AGE? True - if the manifolds are the same to your old motor, no need to swap, if they're different you may need to do so - go and look at everything that runs on, around, and through the manifold to determine your course of action?!
    Aug 2006
    success 6164
    oh ok..thanks guys.really appreciate the help.
    damo
