Results 1 to 11 of 11
Thread: 18rgeu airflow meter swap?
    Default 18rgeu airflow meter swap?
    hi
    my airflow meter isnt working properly. i have tried to find a replacement but am having a lot of trouble.
    is it serviceable? if not are there any other airflow meters that can be used instead?
    any help would be great
    thanx
    Default Re: 18rgeu airflow meter swap?
    In what way is it not working properly?
    I believe the AFM from a 5-ME will work as a replacement for the 18R-GEU
    Beige.... The new Black!!!
    the car wont start with the afm on the throttle body
    when going it idles very rough and occasionally dies when revs are put on
    i was given this test by another toymods member http://www.4crawler.com/4x4/CheapTri...tml#AFMtesting
    i did them and none of the results were even close
    Time to spank the Grease Monkey
    Try one from a 22RE (RT142 Corona or RA65 Celica). I have put one on my 2TGEU, works okay - want to get it on a dyno and check air fuel ratios, but it should work fine.
    AE92 Lueno GT-Apex (zenki Trueno with a Levin front end) - BT 20V & LSD
    KE30 Tudor - 2T-GEU, T50, T292
    thanx for your help guys
    alternative is just get a Megasquirt
    S.A.
    Oh yeh, thinking back i used a 22-RE AFM with my 18R-GEU with standard ecu. It worked fine, although air/fuel ratios were a bit rich down in the lower revs. But its an 18R-G, they love to rev!
    An EFI tuner should be able to adjust the spring tension slightly to remedy this tho.
    on another note, i believe 5-ME AFM/coil/igniter all are compatible with the 18RG standard stuff.
    Quote Originally Posted by 23T-GTE
    As is the wiring loom.... Just cut off 2 of the injector plugs.
    On a related note, does anyone know of a flapper-style AFM which is larger than the 18R-GEU one? I want to put slightly larger injectors in my 18R-GEU, and rather than tightening the AFM spring to buggery I thought it might be a good idea to use a bigger AFM. Does anyone have a 5M or 7M AFM they can measure for me?
    when i get home ill measure the 5m-e one, however the 5m-ge one is even bigger (mainly taller inlet, same width).
  1. 1GEU > MTEU + Auto > Manual in GA61 swap
    By KwS in forum Tech and Conversions
    Last Post: 06-12-2005, 02:36 PM
