Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 157
Thread: Imports101 MaxAction Second Series 2006
  1. #46
    Default Re: Imports101 MaxAction Second Series 2006
    Ahhh....second question then....why is the G series not in yet?
  2. #47
    Wink Re: Imports101 MaxAction Second Series 2006
    Hey Mitch,
    If you break your T-series on Sunday, I could use it to build the LSD into
    Only joking! I want you to have a good run on Sunday so I can see the beastie in flight.
    I'm still drooling over the Hopper Stoppers brake upgrade - one day!
    Gene
  3. #48
    What is this Hopper Stoppers upgrade you speak of?
  4. #49
    Post Re: Imports101 MaxAction Second Series 2006
    There's an upgrade kit for the early Celica (strut type):
    TOYOTA COROLLA CELICA AND CORONA EARLY STRUT TYPE (ask for details)
    Included in Kit:
    • Pair 290 mm Disc Rotors and Pair Twin Piston Calipers
    • Set Semi – Metallic Brake Pads
    • Caliper mount kit with rings, spacers and fasteners
    • Pair wheel bearing sets & Grease caps
    • Pair Conversion hubs made from K1045 Billet steel fitted with bearing cups and Ford Pattern wheel studs
    • Pair custom Brake Hoses and copper washers
    • Full Fitting Instructions
    You need to have at least 15" rims to fit this conversion and you must fit a 1" bore
    Master cylinder to obtain the best pedal feel.
    Please consult us for advice for your application
    I'm keen to do something along these lines to the TA22
  5. #50
    May I ask how much it is? What calipers are they?
  6. #51
    Junior Member Grease Monkey glytch's Avatar
    Quote Originally Posted by JustCallMeFrank
    Here's the actual info sheet. They are about $1200. Perth Brake Parts sells them.
    http://www.hoppers.com.au/toyotacorolla.pdf
    RA40 Coupe - Even more Turbo beating ponies.
    "Give a man a fire and he's warm for the day. But set fire to him and he's warm for the rest of his life."
  7. #52
    W.A.
    Gene if your chasing a T series diff to fit your LSD to i have 2 sitting here. I think 1 has stuffed axle seals, but i think the other is ok all round. Although i'd assume you would test fir it all up then just end up using the centre in your axle?
    Anyway its here if you want one.........or two
    Matty
  8. #53
    Matty, yeah... I think the best way to do it is to use the spare diff to get the LSD centre setup, and then transfer it over to the diff in my car. So, I may just take you up on that offer, although Jenelle's not too keen on me having more parts lying around
    "Sorry dear, it's just for a few weeks..."
    "Frank?"...
    This is the reply I got from Hopper Stoppers a while back (he also said Perth Brakes should charge the same), but freight from Vic would be about $60 if you ordered it direct from Hoppers:
    We do a 290 diameter by 28 thick twin piston upgrade for the TA22 front strut, based on AU3 XR8 vented Falcon rotors and calipers adapted to the Toyota strut with our custom steel hubs and brackets.
    Rotors are bought as blanks so 4 or 5 stud pattern is possible
    All parts are included, nothing else to buy. (Only complete kits are sold, no loose hubs or brackets.)
    Kit has hubs, bearings, seals, rotors, twin piston PBR calipers, pads ,brackets, bolts, spacers and hoses, at $1100 with smooth rotors,
    $1200 slotted, $1250 drilled and slotted.
    Calipers can be red, yellow or black or straight alloy all same price.
    Your Simmons 15 inch wheels will fit but sometimes we find the ring of nuts holding the split rims together just touch our calipers and a 8mm wheel spacer is needed.
    You should also fit a 1 inch master cylinder , we have a bolt on item at $220.
    Adjustable prop valve may be needed depending on which diff/rear brakes you run or maybe we can tune rear brakes with different size wheel cylinders?
    I think it's also possible for a Camry 2 Brake Booster to be used on a TA22 (according to another Toymods post) - part number 47201-06190? Wonder if Loz could get a price on one for me Matty?
  9. #54
    Haha, who has car parts lying around? *Looks at his 3 1G's*
    Thanks for that Gene. Any idea of the piston sizes on those PBR's?
  10. #55
    W.A.
    HAHAH *Matty looks at his 3 1G's his 2 1J's his 2 2T's his 2 5M's his 7M his 18R and his 4AG* dont even get me started on parts Nathan
    Gene just to clear something up...as silly as it is, Just Call Me Frank's name is actually Nathan Yep i dunno, puzzles me too.
    Im sure Loz can get ya price on that part number, i'l ask her for ya.
    And i know you want both of my spare diffs you wouldnt want one gettin lonely hehe
    Matty
  11. #56
    Bahaha, tis a long story
  12. #57
    Quote Originally Posted by Wildsupra
    Stomps why not enter the T18?? Its basically a sprinter hehe
    Matty
    ha, and what.. roll it...
    adam has a full roll cage, 2 seats, a couple of grand worth of suspension, has welded the chassis in various points for even more stiffness.. and has a 4age.. lightened flywheel.. .and not to mention wider then 155 tires..
    i have a 3t, crap paint job and some old springs.. i dont like my chances..
    cyas tomorrow
  13. #58
    Talking Re: Imports101 MaxAction Second Series 2006
    Matty
    Ahhhh, obvious really...
    Hi Nathan, I don't have the pistons sizes. Just shoot off an email to Hoppers, they'll give you an answer.
    Thanks Matty and Loz. I'm sure I'll be able to hide the diffs somewhere where J won't find them
  14. #59
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Its in the ain't broke, don't fix it category mate, no need until it let's go....
    RA23
    1G-GZE
  15. #60
    WA (Perth)
    I would be interested in finding out more about the adjustable brake prop. valve in the Hoppers Stoppers package, especially when the Hilux rear axle goes onto the back on my car.
    RA23
    1G-GZE
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 08:43 PM
  3. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
  4. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 07:51 PM
