Results 16 to 20 of 20
Thread: EDIT: 1jz runs rough when warm!! help
    Dec 2008
    western australia
    Default Re: EDIT: 1jz runs rough when warm!! help
    check the plugs , colour and condition.. might of burnt an electrode , or if they are white , might be running way lean and not getting enough fuel (surging rather than pinging )
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    plugs are fine pulled em today for a look! regapped them, seems to not have a miss much anymore but just turns off without warning when temp gets up then only way to idle is with the go peddal soo friggin confusing
    1992 JZA70 AEROTOP LIMITED WITH A 400+HP GOAL
    Junior Member 1st year Apprentice Jman's Avatar
    Aug 2006
    I'm having same issue. Any luck?
    My 1jz is missing up in the revs (basically +2500rpm) only once it's hot, and then also not holding idle from then on.
    I've done ecu swap (std ecu), new coils, new plugs, new 2 x cam and crank angle sensor. Also had my ecu recapped (as it had leaky capacitors) with no change.
    So now I'm trying to source another ignitor to try, also going to try change the fuel filter with a new one and swap map sensor (std 1bar is in it).
    I'd try the fuel filter, just in case there is a fuel supply issue up in the revs.
    The only error code I'm getting is EFI 13... which points to cam sensors or ignition related. I was get EFI 14 as well intermittently which the new coils/plugs seem to have cleared up.
    western aus
    Well i fixed my idling issue it was my TPS (throttle posistion sensor) asoon as the car warmed up the TPS hadnt been ajusted correctly and would just stall. played with that and now is fine. i replaced ,igniter,fuel filter,coilpacks,plugs litterally everything and yer ended up being the TPS.
    Aug 2006
    Cool.
    I just need to work out how to adjust the TPS then.
  1. 1JZ problems
    By cressida_1jz in forum Tech and Conversions
    Last Post: 01-09-2007, 01:57 AM
  2. MA61 + 1JZ + Heater problems
    By Gibbon in forum Tech and Conversions
    Last Post: 11-05-2007, 02:25 AM
  3. 1JZ auto problems
    Last Post: 20-11-2006, 08:38 PM
  4. 1jz problems with idle and snapped off screw head.
    By tyottsoarer in forum Tech and Conversions
    Last Post: 22-05-2006, 11:39 AM
  5. 1jz vs 2jz heads
