Page 7 of 7 FirstFirst ... 567
Results 91 to 105 of 105
Thread: converting corolla from 4x100 to 5x114
  1. #91
    Forum Member Grease Monkey ap7's Avatar
    Default Re: converting corolla from 4x100 to 5x114
  2. #92
    Sep 2009
    I will take the stub to work tomorrow and have a go at machining it down.
  3. #93
    Sep 2009
    Hello
    Here is the new Corolla rear five stud stub axle.
  4. #94
    Hey, new as in 5x114.3 or new as in you managed to machine the 5x100 down to 28mm?! Looks like I am gonna have wheels on my car sooner than I thought! lol
  5. #95
    Sep 2009
    Hello
    I machined the st204 stub down to match the Corolla Stub.
    Its a 5x100 pattern.
    If you wanted 5x114.3 then you would need to fit a different brake rotor.
    If you want a pair let me know. Do you want to fit new rotors or reuse your old ones? I can drill the rotors to suit the stub. I can also supply the front drive flanges as well.
    Corey
  6. #96
    Hi Corey,
    Yes please! I want 5x100 and new RDA slotted discs please. Also how much will it all cost?
    And thank you!!!!!
  7. #97
    Sep 2009
    I will let you know the cost.
  8. #98
    Sep 2009
    Hello
    Can you tell if you have ABS on your car? I see in the picture of the stub axle it had a cutter wheel attached and you can see where it was snapped off.
  9. #99
    Quote Originally Posted by Xauterus View Post
    Hello
    Yes, I have ABS and the cutter wheel did snap off!
  10. #100
    Corey
    Your inbox is full, cannot send pm's!
  11. #101
    Sep 2009
    That should work better now
  12. #102
    Jan 2007
    queensland
    Thread Dig -
    kinda noob questions - has anyone just tried to put all 4 corners off a 10 series wide body camry, brakes, hubs etc in to an ae92/101/111?
  13. #103
    Sep 2009
    The first of the wide body camry drive flanges may be able to be adapted to the corolla. I did look at this conversion a while ago. You need to check the CV joint spline. Some I looked at had a larger spline so would not fit. The upright has completely the wrong geometry and shape to fit the corolla. The rear uprights are also completely different. Might be able to modify the rear drive flange to fit the corolla bearing, but then you will need a rear disc conversion to slip the rotor over. Would also need a custom brake setup on the front too.
    You should look at mid 2000s corollas that went to 5x114.3. They might have the same spline cv joint.
  14. #104
    Nov 2017
    westmoreland
    anyone manage to do that 5x114.3 swap one the ae100 corolla
  15. #105
    Sep 2009
    Quote Originally Posted by stephanx7 View Post
    First gen Rav4 flange will fit on the front. You would have to find a rotor to fit. On the rear look at later corollas wiith 5x114.3 pattern. I havent found a solution for the rear yet.
  1. Leaf Corolla spring saddle insulator rubbers?where to get??
    By Aust162 in forum Tech and Conversions
    Last Post: 09-03-2013, 02:52 PM
  2. Toyota Corolla Ceres GT engine 4AGE 20V to Corolla EE100
    By mitman in forum Tech and Conversions
    Last Post: 07-06-2010, 12:31 PM
