Page 1 of 7 123 ... LastLast
Results 1 to 15 of 105
Thread: converting corolla from 4x100 to 5x114
    Chiba
    Default converting corolla from 4x100 to 5x114
    Ok, I'm sick of having a hard time finding decent rims to fit my Levin. I have massive brakes and need 17" rims etc. And have had to pass up heaps of good rims at good prices because of this stupid stud pattern.
    So, as part of the build, I want to convert from 4x100 to 5x114.
    I plan to get some front hubs from a celica or the like and grind them down to fit, I mean, lathe....
    For the rears I'll look to do the same, so I can retain the stock brakes and knuckles etc.
    Does anyone know of the possibility of this working? I have the Corolla hubs, so I guess I need a set of 5x114 hubs that are close in size that I can turn down.
    Any ideas?
    wa
    Default Re: converting corolla from 4x100 to 5x114
    well the celica have 5x100 so that won't work.......
    93 on camry's will be easy to find to grab cheap hubs and have the 5x114.3
    Chiba
    Ah true. I'll look at Camry hubs then. Does anyone know the sizes of the bearings used in Corolla and Camry hubs?
    If I could modify the Camry spinny hub bit to fit the Corolla knuckle (I want to use my super strut gear) that would be ideal.
    fwiw: Camry/Celica (well, at least around the ST185 era - which fits with your potential donor: '93 Camry) use the same wheel bearing kit.
    Whether the wheel mounting face is in a suitable spot/offset with regards to the caliper mount (Corolla versus Camry) is unknown.
    Chiba
    sweet. I'll have to head down to the wrecker on the weekend.
    wa
    i have a bearing and hub from an sw20, i was told these are the same bearing as the sdv10's widebody camry.
    i'll measure when i get home.
    Surely it would be easier to convert to 5x100 ?
    Or are rims just as scarce in that pattern too?
    May 2006
    tas
    by far the easiest way is to just get 5 stud hub caps and fit over std steel wheels.... LOL
    im not sure if its possible to get 4x100>5x114 spacers?
    edit: i thought there where a lot of nice wheels in 5x100
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    wa
    i know plenty of people tend to have a hard time getting 5x100 rims in offsets they want to suit celica's, most 5x100 are to suit wrx's and the like and have 40+offsets.
    dunno what offsets your looking for the corolla's tho.
    I've seen a few 5-stud conversions done on AE10Xs over in the US, can't remember what they used though.
    And whilst 5x100 is a pain to find in the right offset, don't multi-fit aftermarket 5-stud wheels cover 5x114.3 and 5x100 normally? Or do they use 5x114.3 and 5x120 (Falcon and Commodore respectively) instead?
    Jul 2008
    Auckland
    Terra, there is 1 major problem, the brakes i supplied you are Celica discs, the inside diameter only just fits a 4x100 or 5x100 drive flange. If you move to a 5x114 drive flange the diameter will be much bigger and wont fit inside the celica disc.
    Now 9AGTE 410kw atw
    Quote Originally Posted by Hiro View Post
    Normally the 5 stud Japanese dual PCD stuff is 114.3 and 100.
    There are a few 114.3/120, but its not common.
    I've got a set of 5x100 +38 17" Momos that I might want to get rid of too....
    Chiba
    Hmmm, I didn't think of the rotors not fitting. I'll have to check that the calipers sit far out enough too.
    I'll check out if I can get any decent rims in 5x100, if so that will make things fit easier.
    Jul 2007
    why not convert to 4x114.3? i would have thought that would have the greatest choice in wheels by far? although i guess a lot of them are 14-15".....
    pcd conversion spacers not an option?
  1. Leaf Corolla spring saddle insulator rubbers?where to get??
    By Aust162 in forum Tech and Conversions
    Last Post: 09-03-2013, 03:52 PM
  2. Toyota Corolla Ceres GT engine 4AGE 20V to Corolla EE100
    By mitman in forum Tech and Conversions
    Last Post: 07-06-2010, 01:31 PM
