Search the net for something like "AE101 wiring diagram" or "AE101 ecu pinout". There's a lot of info out there.
note: most people will know the ceres as an AE101.
Hi all,
Im making swap of 4AGE 20V ST from Toyota Corolla Ceres GT to my Toyota Corolla EE100(old engine 4EFE).
Engine is now mounted in my Corolla.
But I have problems with eletric wiring.
I need you help to find(or if any body have) Toyota Corolla Ceres GT repair manual or wiring diagram.
Ceres is : TOYOTA COROLLA Ceres GT JPN SED 4AGE ATM 4FC 4D (AE101-AEPVF)
If anybody have any manual please tell me.
Thank you.
The 20V engine wiring will be the same as a 20V from a Levin or Trueno.
The Ceres isn't a common import so body wiring diagrams will have to be sourced from Toyota. Body wiring diagrams for the Levin aren't even around and the Levin is a much more common import.
A multimeter will help you quickly trace wires if you're unsure.
AdrianS: thank you for info ;o)
TERRA Operative: Ok, so I will try Toyota for body wiring diagrams. Im not so good electrician but mutlimeter is good helper
All: Is good opinion to use body wiring from Ceres and swap it to EE100?
And some photos of my cars:
Swapped engine to Corolla E100(model:1993)
Donor car and engine in donor car:
My car before i start swap:
On an aside note.. Do you still have the donor car? If so, how much do you want for the ABS brake lines on the drivers side strut tower (the ones going to the ABS motor behind the headlight)?
I'm desperate for them!
Check out here for wiring info applicable to the 20V silvertop engine you have. That should help you a bit.
http://www.club4ag.com/technical_main.htm
If they're the same as the ABS lines in the AE101.....
Terra : This is the BZR :
http://www.toyodiy.com/parts/p_J_199...CFVF_4708.html
Is this your levin ?
http://www.toyodiy.com/parts/p_J_199...XR_4708.2.html
If not, what model / year is it, so I can find it on toyodiy ?
Yep, the ACMXR is my model. PM me a photo of what you've got, I might pick the bones of your front cut....
Ok, I'll do that. It may not be tonight, as the half-cut stuff is in a pile of boxes in the shed.
