Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 105
Thread: converting corolla from 4x100 to 5x114
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    Default Re: converting corolla from 4x100 to 5x114
    hmm i thought my rims were off an N15. ok disregard my previous post
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    Aug 2009
    It also from a UK website so there maybe some differences between international markets
    ever thought about getting a 5 x .... or 4 x 114.3 pcd rim redrilled to 4 x 100?
    have got it done to a 4 x 114.3 15" rim in brisbane, seems to be prity comon oversea's too.
    Chiba
    I'm thinking of getting my hubs redrilled to 4x114.3, as that is more common, then I'll slot the holes in the front rotor (it's already redrilled from 5 stud) and redrill the rear rotor (which is stock).
    If I can find more rims in 4x114.3 that is.
    Sep 2009
    Hello
    You will brake through the edge of the up almost with 4.5". Its 7.15mm further out on radius than the 100mm PCD. Im certain you would break through.
    You could probably get a shop to plug the old 4x4.5" stud pattern and then redrill 4x100mm. Theres no metal to redrill rims as they are all hollow in the other quarter.
    Corey
    Sep 2009
    There is a rule for offset too. Only alllwed to make the track of the car 1 inch wider overall.
    Quote Originally Posted by Xauterus View Post
    Hello
    Corey
    a lot of rims have solid center hubs, making them easy for a rim specialist to re-drill pcd's.
  8. #38
    This thread is full of so much mis-information.
    Why not just add bolt on spacers which change the stud pattern and run the appropriate offset wheel.
    OR just live with it being 4x100 and get wheels fitted to that stud pattern (custom)
    Or just get a car with 5x114.3 pattern.
  9. #39
    Nov 2007
    Subaru's use 5 x 100 stud pattern. Lots of wheels out there for the rexes.
    i.e if you go with the celica option.
  10. #40
    Chiba
    1. Not happening. I've been defected once and with the 'hoon' laws, my car gets impounded the next time. This build is going to be all legit (or built in a way that it looks legit).
    2. Trying to do something like that, but I'm not dropping a grand per rim. 17" in 4x100 PCD is hard enough to get, and even those are mainly +40 to +45 or so. I need +35-ish.
    I'd rather just save the cash for a set of Gram Lights or Volks.
    3. Not a chance.
  11. #41
    Jul 2007
    if you cant find 4x100 in a +35 offset then you arent trying hard enough. just look on ebay US.
    try finding 4x100 wheels in 0 or negative offsets, now THAT'S hard
  12. #42
    Chiba
    It's easy in 15", but in 17" all I can find is trash knockoffs that weigh 20kg each or are thin and weak, or Uber expensive Jap rims (which are in the plans, but that's later)
  13. #43
    How strong a wheel you looking for?
    I'm going to be selling my Dina shortly & I'll be refitting the Stock brakes & wheels back to it.
    I'd bought some 17x7 in a +38 offset which just cleared the ST205 GT4 brakes I've got fitted.
    These are a 5x100 pattern.
    The wheels are quite light, & the boxes say they're liquid forged, but for $1000 for the lot (with rubber is extra)
  14. #44
    And, I may be coming up to Brissie in a couple of weeks for the weekend, so I can bring one with me if you want to check them out.
  15. #45
    Forum Member Grease Monkey ap7's Avatar
    Was this ever sorted? I am looking at this as well now as there is just not enough 17 or 18's with sub 35 offset for my Levin/Trueno. I want Work cr's in white....
  1. Leaf Corolla spring saddle insulator rubbers?where to get??
    By Aust162 in forum Tech and Conversions
    Last Post: 09-03-2013, 02:52 PM
  2. Toyota Corolla Ceres GT engine 4AGE 20V to Corolla EE100
    By mitman in forum Tech and Conversions
    Last Post: 07-06-2010, 12:31 PM
