Results 46 to 60 of 87
Thread: Whats the upgrade path for a 1ggte
  1. #46
    Default Re: Whats the upgrade path for a 1ggte
    Quote Originally Posted by Nark
    Maybe I'm growing old.
    But even when I'm driving quickly in traffic, I reckon I'd only spend 10% of the time on boost. If that.
    Think about it, the only time you use boost is when you're accelerating, and it doesn't take long to accelerate to the speed limit. The rest of the time is off boost. Unless you want to drive around in 2nd gear (which I occasionally do).
    The only time when off boost performance doesn't count is when you're on a twisty bit of road with no traffic. Or the track.
    And how often is that for a daily driver?
    dude, i drive the celica 5days a week to work (when its running! lol!)
    the 1g has plenty of torque and power off boost (in an 1100kg celica atleast!!)
    blake
  2. #47
    mel
    nice them maybe i should go 3 inch lol
    depend on how much fast i can save the money dont think uit will happen anytime soon
    any idea about the timing i mentioned before
    Forum Member Domestic Engineer Nark's Avatar
    ACT-ish
    No doubt dude, it's an awesome engine for the Celicas.
    Problem is the engine matched to the weight of an GA70, not the engine itself.
    Max
    NB8B MX-5 | Fulcrum-tuned Tein SS coilovers | Weldwell Engineering 4 point Rollbar | DBA 4000 slotted rotors | Goodridge braided lines
    MY11 Skoda Octavia RS wagon | 2x ISOFIX seats | Iggle Piggle's blanket | Some breast milk stains
  4. #49
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    Quote Originally Posted by purple5ive
    karmasupra im sure that air expand when hot not when cold
    Yup! it does. Because it has expanded it is less dense! I read somewhere that when it is in its hot expanded state, even though the volume is greater, because the density is lower it flows better. It makes sense theorticly, I was just wondering if anyone can comment as to how usefull it is in application!!
    the fact that the factory y pipe is roughly 2-2.5 inch dia im in doubt as to what to do since the y pipe is small will there be a improvement fitting a 3 inch after , because the exhaust is only flowing as good as the biggest restriction(in this case the y pipe) up to the cat anyway isnt it
    That is the point I was trying to make last night... You just put it better I'll measure it up later to confirm it
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
  5. #50
    The same could be said of most turbo exhaust housings, they're a lot smaller than most exhausts.
    Most of the plugs I've found that are the right model for the 1G come with 1.1mm gaps, and ideally the GTE should have a 0.8mm gap. Sorry, I missed that with my previous response.
  6. #51
    mel
    Thanks lads
    Karma either way we both after the same thing lolll, I hope so hopefully we get the right answer cheers matey
    Also I decided to go with jcmf earlier advice as to not going mandrel beds after the cat, cause it made sense about the gases cooling down a fair bit while in the cat converter and hence not needing much room to flow down towards the exit/muffler which is why mandrel bends is not necessary,
    But what frank says about the turbo exhaust being smaller than the main exhaust itself makes sense as to why you couldn’t go 3 inch
    Jcmf thanks matey so im aiming for 0.8MM gap I dunno what in there atm but will get my mechanic to check and re gap them
    Ive been also told that the 22 dollar iridium or platinum ones don’t need re gapping blah, blah etc is that true ?????
  7. #52
    mel
    also forgot to ask
    any idea what that small probe like thing is in the cat for ???
    mine got take out when i fitted the new cat and was never hooked back is it necessary to be hooked back up into the cat or should i just leave it
  8. #53
    Oxfordshire
    That probe thing is the sensor we were talking a bout earlier. I think it is the cat temp sensor, for the cat overheating warning light. (It has to be!) some muppet at toyota told me it was a second lambda sensor, but I don't believe him!!!
    Some kind of BMW
    ..::VVTi 1UZ-FE::..
  9. #54
    Car isn't new enough to have a second lambda sensor. It's definetly a temp sensor for the cat.
  10. #55
    mel
    can we leave it unplugged then or should it beplugged back up
    what the deal with the cat warning anyway obviously its to show ur runnign too rich but anyother reason why there a hot cat warning light
    Because an overheating cat 1) doesn't work properly, and 2) is likely to fail entirely
  12. #57
    Oxfordshire
    Cat?????? Whats that?
    JustCallMeFrank Thanks for confirming that anyway... I knew the guy at toyota was talking shyte.
    I must admit even when I had a cat, I never got the light to light up... Mayeb our climate has something to do with it too!!!!
    If I disconnect the thing from teh loom (there isa plug under the carpet) am I likely to get any error codes?
    Some kind of BMW
    ..::VVTi 1UZ-FE::..
  13. #58
    TAS
    Quote Originally Posted by 86TT
    Easy. Put it in an xA6x
  14. #59
    vic
    i used to run a 440hp gt2871r on my 1g, spool was fantastic on 15psi, absolutly killed the stock turbos and made it a quick street car but seeing as your car is a ga70 upgrade path, drop in a 1jz, its way better motor and gives you the torque you need to get it of the line
  15. #60
    TAS
    Quote Originally Posted by Stefan
    Funniest post I've made in a while (admittedly, that's probably not saying much), and not so much as a giggle.... sigh.
  1. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 08:15 PM
  2. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 03:29 PM
  3. 1ggte fuel system mods
    By MOOKIE in forum Tech and Conversions
    Last Post: 03-01-2006, 12:15 AM
