Page 15 of 24 FirstFirst ... 51314151617 ... LastLast
Results 211 to 225 of 353
Thread: Micotech 4AGTE
  1. #211
    Hoppers Crossing
    Default Re: Micotech 4AGTE
    my new bosch BOV on my old supercharged v6 vn used to be noisy as also. it used to vent at idle!
    so your turbo couldn't drain enough oil when it was plumbed into the factory return for the oil cooler? i guess that foils my idea then, bugger, that is a pity. will be a bastard to get the sump off in RWD format grrrrrrrrr.at least in FWD you have the front and rear gearbox mounts to hold the engine in and can drop that middle thing out.
    nice work with the brazing on there too. keep an eye on it ; should be fine.
  2. #212
    Jul 2010
    Just opened up the BOV for a look as you do when your not sure all seems to be fine !!!
    it as a bleed by hole ??? (not sure why it needs that when it stays open till the vac drops ??) hooked it to the vac and it opens and shuts fine so all good !!!!
    Also got my Lc-1 working on the lappy so just need someone to drive it while i tune !!!
    Grega that's not braze it's soft solder But its doing well so far
    And on the oil drain prob ... This is what ive come up with !!!! If you have a longer steeper drain it might work ??? but if your turbo is close to the sump you will need a bigger drain into it !!! Also if your using a bush bearing turbo they flow more oil so will also need more flow then a BB one !!! just deepens on how high you can get the turbo Really
    mine only has about 10mm fall to the sump and about 100mm of pipe so it fills quick which ill have to work on But its working for now
    Hope this biography Helped
    Ae90 Hatch 4AGTE Small port http://www.toymods.org.au/forums/showthread.php?t=64566
    Same car More info http://www.toymods.org.au/forums/showthread.php?t=63892
    LAUGH NOW CRY LATER ! Cars and Girls will do that to you !!!
  3. #213
    Quote Originally Posted by Adams4AGTE View Post
    but at the end off the day im not a fuck wit that has no idea!!!
    So who else is predicting a dead engine from oil starvation soon?
  4. #214
    Jul 2010
    Not me
    I did ask you to stay off my thread !!!
  5. #215
    I know... but seriously, you used lead/tin (electronics) solder??
    Thats just asking for trouble!
  6. #216
    Jul 2010
    I know but that's my loss or gain ????
    Not your problem !!! and once again your here ????
  7. #217
    Hoppers Crossing
    oh, adam soft solder mate, as in electronic solder? be very VERY careful mate. i don't think that will hold up under the heat bud. keep a very very close eye on it dude.
    hmmm, just thinking about my old VL Turbo, the oil return from that was only short, BUT thinking about it, it didn't drain into the sump, it drained into the block on the old RB30, so I guess oil level wasn't a problem hey.
    I'll get a angled speedflow fitting and try it when the time comes, otherwise I'll pull the sump off and sort something like what you've done dude.
  8. #218
    Adam - just go with what you know works and stick to it mate! as Grega has said, keep a good eye on that drain though, but we have covered this already in earlier posts in this thread.
    I don't know why people keep hacking on others when this is meant to be a forum who welcomes people and provides knowledge and help to those who want it.
    Basically what I am trying to say here is, if you have nothing positive/constructive to say, then keep your comments to yourself.
    We are all (most of us) here to learn and help others with what we have come across, I for one find it incredibly annoying, when you are trying to achieve or try something out that you think will work, and somebody flames the hell out of you.
    All in all, good work so far mate and keep it up, you have displayed a good learning curve, and after all thats what counts!
    Last edited by RT40Corona4AGTE; 04-01-2011 at 07:36 PM. Reason: grammar, punctuation, etc
  9. #219
    Can't touch this Backyard Mechanic boona's Avatar
    Aug 2008
    ^^^^ Agree 100%
    1987 AW11 MR2
    AE92 4AGZE, S15 T28, Adaptronic E420C build in progress
    http://www.toymods.net/forums/showthread.php?t=53945
    Professional: www.danswell.org
  10. #220
    Jul 2010
    Quote Originally Posted by RT40Corona4AGTE View Post
    Here here bud Thanks So much for all the help that i have got from all the GOOD people on here that want to help and no just hack !!!!! I have learned so much and im willing to put my ass on the line to try some thing that MAY OR MAY NOT work ???? Which i said in the post !!!! At the end of the day im the loser or everyone is the winner !!!
    i do research all the pro's and con's and sum up the out come before going through with my trials !!! i have full faith that this will hold up longer then anyone thinks ??? But i gess will see how it goes, because im not scared to admit when im WRONG !!!!! in this case it could be really bad but thats what life is about !!!!!
    Thanks to all that helped and ill do my best to help everyone out with anything i can !!!! THAT'S WHAT WERE HERE FOR !!!!!!!
  11. #221
    Sep 2009
    aight.. time to start hackin up the local asphalt
  12. #222
    ^^^^^ agreed! proof will be required though, of course
  13. #223
    Jul 2010
    YEP for sure as soon as the tune is done the will be proof !!!
    Got 4 new stockis siting out the back in waiting !!!!
  14. #224
    Jul 2010
    Here's how not to make a farking dump to cat pipe !!!!!
    flange down to 2 1/2in then down to 2 1/4in inside the farking thing !!!!!
    they made the farking thing out of 2 1/4 press bent pipe and put a Farking 3in long flex joint in ?????
    little pissed !!!!!
  15. #225
    hmm well thats not what I would've done
    you are pissed.....understandable.
  1. 4agte clutch setups
    Last Post: 26-06-2008, 11:32 AM
  2. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 10:46 AM
  3. 4agte Info
    Last Post: 16-03-2007, 08:15 PM
