Page 5 of 24 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 353
Thread: Micotech 4AGTE
  1. #61
    Jul 2010
    Default Re: Micotech 4AGTE
    Quote Originally Posted by Adams4AGTE View Post
    mmm got upto operating temp and stalled and wont startand timing is back to 10deg
    OK this is what Ive done to get it to start when its hot ???? adjusted the TPS setting to 3% and it starts and idles ?? probably not right but works anyone know this is happening ???
    just wish that there was someone in Sydney that would come and talk to me about the tuning side so i could understand how it all works properly
  2. #62
    Simple MT tuning isnt difficult for someone to pick up that who knows the basics of fuel/ign tuning and how ECU's work.
    Sorry... but its starting to sound like you dont know the basics
    When i say "basics", its not a small amount of knowledge... there is a lot to know & learn.
    Unless you have a lot of free time you can dedicate to learning this stuff, then learning how the MT works, and then tuning it, i suggest you get a pro with a dyno to do it.
    Its not easy, can be frustrating (especially with MT's) and you can kill an engine (esp turbo engines) pretty easily if you get it wrong.
  3. #63
    I wasn't trying to be negative at all, just informing you so you dont ruin your engine
    Your TPS needs to read 0% with throttle closed at idle. if you have to take it above that for it to idle then you are running off the load maps instead of the idle maps (tps above 0% switches to load maps from idle maps). change this with the TPS CAL function.
    Base static timing should be set to 10 degrees, with TIMING LOCK ON. Do not rev the engine with TIMING LOCK ON.
    I will try to put together some values for you as a starting point in a spread sheet if you like?
    Once again, I was in no way being negative at all.
    I assume your injectors are std and so is your fuel pressure?
  4. #64
    Jul 2010
    Quote Originally Posted by RT40Corona4AGTE View Post
    yeah all still standard
    timing is set at 10deg with timing lock on and ive checked that is wright more times then i can count
    the settings above worked till it got hot then it just stalled and wouldn't start an till i moved the tps setting in the mt (which i know is not wright and its running in load ) but its the only way it would start
    if you could do some base settings for me it would help me heaps
    i will add once againe that this is my first EFI tune and that im trying to learn as much as i can before i bolt the turbo on.... ive built and tuned a few carby fed na motors so i know when it is pinging and i all ways have the tune abit rich when trying new things....
    ive spent the last three days reading the manual that i have but its preety basic as we all know thats y im looking for more info all the time trying to get my head around this and when it clicks it will be sweet .....
    Thanks for your time
  5. #65
    try looking at your value of vacuum in the load map that it is running at (ms) and making your vacuum value in the respective idle map equal to it. then re-cal TPS and see if it starts. Basically get it running and then throw a wideband on there to sort out the AFR's. Timing maps I should be able to assist you with. Will take a look at home tonight and see what data I have.
  6. #66
    Jul 2010
    just went through all the memcals and there all the same???? i didn't do it ??
    the old owner had a 20v turbo then he changed it back to no turbo as he was a p plater i think that he has stuffed with all the maps trying to get it to work
  7. #67
    Jul 2010
    thanks bud i did try that with no luck
  8. #68
    have you checked what your crank maps are at low and high temps? also what are your water temp correction values?
    actually, can you PM me all of the values out of your microtech? if you have them readily available that is.
    I just realised they are in your video, but if you have got them down somewhere could you scan or type them up for me?
  9. #69
    Jul 2010
    I just realized they are in your video, but if you have got them down somewhere could you scan or type them up for me?
    hi i don't have them written down yet had to switch back to the factory ecu last nihght so i can get to work
    all the values in the vid are wrong and ive spent some time playing with them as they didnt work ...
    will plug it back in and wright down them down to night and send them to you so you can have an idear on how far out they are ??? im starting to get my head around this and have got the tps back to o% when starting hot but the temp fuel settings are very high
    thank ill get all the settings to you to night
  10. #70
    no worries we should be able to get to a happy start-up medium and then go from there. Do you have access to a wideband mate?
  11. #71
    Jul 2010
    not as yet I'm saving up some coin to bye one
  12. #72
    excellent! you wont regret buying one!
    I will try to get on the PC tonight to take a look at your values when you send them through.
  13. #73
    Jul 2010
    here i is cant pm it ??? thanks bud hope you can understand it
    follows the screens in the mt
    this is better then the saved maps in it lol
  14. #74
    whoa the timing is up the shit.... lol
    lets see if we can fix that. PM me your email address bud!
  15. #75
    Woah, yes thats very wrong...
    This is what mine looks like:
    http://gt4.mwp.id.au/Engine/MWP%20Ignition%20Map.png
  1. 4agte clutch setups
    Last Post: 26-06-2008, 12:32 PM
  2. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 11:46 AM
  3. 4agte Info
    Last Post: 16-03-2007, 09:15 PM
