Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
Thread: Fuel System setup for 4agte
    Junior Member Backyard Mechanic dangdang's Avatar
    May 2010
    TAS
    Default Fuel System setup for 4agte
    Next step in my build is the fuel system, was thinking..
    Factory pump to lift into swirl tank and then feed a main pump, ???? any ideas
    And fuel reg, retain the standard reg or go Malpassi etc?
    Thoughts Toymodders?
    Default Re: Fuel System setup for 4agte
    Expected power level?
    Given you have an ae82, with an intank EFI setup already, why don't you just put a walbro / bosch pump in tank (Assuming that your expected power figure can be achieved with one pump) Why make it more complex than it needs to be?
    I'd keep the stock reg if it is capable.
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2010
    TAS
    Cheers Wilbo
    200kw+ is the aim, so a system that can support 250kw would be my aim.
    True, KISS, keep it simple stupid should be the aim where possible, I will look into the intank pumps.
    Anyone using the factory reg with a boosted setup successfully?
    May 2010
    TAS
    Would a Walbro 255lph intank be a safe bet?
    How can I work out my fuel supply requirements, I remember reading a formula somewhere?
    Few ways to work out your requirements...
    1) Injector size
    2) Fuel type and efficiency of engine
    Injector size is by far the easiest Also worthwhile looking at the fuel pump curve vs pressure to make sure that you take into account the fact that your fuel pressure increases when on boost (1:1 FPR)
    i.e.
    Walbro @ 75psi (40 base + 25 boost) ~200lph so that's approx 3333mL / sec, so ~833cc injectors in a 4cly...
    http://www.jayracing.com/images/Bosc...lbro_255HP.JPG
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2010
    TAS
    I did a calculation using a formula I found a while ago and came up with a figure for the injectors of 550cc, plus any larger and I would start losing driveability low in the revs and a good idle as I figure it.
    By that chart you posted I can see why the walbro is a lot cheaper.
    The 82 intank is the same as the supra's isnt it?
    Walbro 255 intank pump is your cheapest option, easiest installation and will support the power you talk about. I have seen them produce 200rwkw on cars that run e85 which requires 30% more fuel than ULP.
    550cc sounds about right for ULP
    Roger
    A Walbro will easy do 4 x 550cc injectors so yeah I'd recommend that
    Sorry I have no idea about AE82 fuel pumps!
    Wilbo's JZA80
    Wilbo's JZZ12
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    As mentioned, depends what power you're after…and how reliable you want the system to be.
    Also, what fuel you intend to use.
    I'm using:
    Carter Gold lift pump
    Surge Tank
    2x Bosch 044 pumps
    rx7 550cc Injectors (direct bolt-in for 4a)
    This is in anticipation to be running E85 when I up the boost, at which time i'll switch to 800/1000cc injectors.
    Jul 2007
    either a walbro or a bosch 040 intank pump. both will flow enough for your needs. walbros are not warranted for use on E85 so if you're going that way I would recommend the bosch unit. if you are circuit racing you might want to use an 044 (identical to the 040 except its for external use) with a surge tank.
    as for FPRs, i thought you needed something aftermarket so that you can increase fuel rail pressure to compensate for boost pressure at that kind of boost level??
    Jul 2007
    oh almost forgot,
    I'm using a Tomei type S regulator…got it from JEM for a very good price.
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    Fuellab pressure regs are the go. Alcohol compatible, you can get various psi ranges ie 25-90psi.
    Pricing is also great on those.
    you have 2 options, intank pump only, then a walbro or bosch. There can be surge under 1/4 tank and those walbros dont like sucking air!. Over time they get noisy from this, thats what happened to mine.
    2nd option - surge tank setup. Run the stock pump as the lift, then a bosch 040 external pump, 044 if you really feel the need. The pumps are not quiet either, quite noisy. Surge tank setups are $$ as you need to run teflon braided lines to run the alcohol and stop fuel smell.
    Now 9AGTE 410kw atw
    Jul 2007
    Quote Originally Posted by Bazda View Post
    The 040 and 044 are identical pumps (they are the bosch equivalent to a walbrobro 255), only that the 040 is for intank use, and the 044 is external. But otherwise they are exactly the same specs.
    Jul 2008
    Auckland
    sorry wrong part number! 979.
    Now 9AGTE 410kw atw
    Low rep 1st year Apprentice
    Aug 2010
    I am currently working on making mine all intank, will post some pics soon.
  1. Fuel system advice.
    Last Post: 28-07-2009, 08:55 PM
  2. Fuel system Q's
    By benny c in forum Tech and Conversions
    Last Post: 22-09-2008, 02:28 PM
  3. fuel setup question
    By connection in forum Tech and Conversions
    Last Post: 02-09-2008, 01:39 AM
  4. fuel system - legalities
    By J0RD0 in forum Tech and Conversions
    Last Post: 26-11-2007, 06:35 PM
  5. make my 1g louder!!!??
    By rollsy in forum Tech and Conversions
    Last Post: 16-02-2007, 09:32 PM
