Results 16 to 30 of 52
Thread: Fuel System setup for 4agte
    Default Re: Fuel System setup for 4agte
    I feel like in general you guys might be leaning towards going a bit over the top IMHO
    Personally I would much rather have one in tank pump as this is going to be more reliable than either multiple pumps in parallel (how will you know when one fails / gets tired?!), and also a lift / high pressure pump...
    Being an EFI fuel tank the fuel tank is already designed to have a high pressure pump in it, so I don't understand why surge will be an issue for a correctly mounted upgraded intank pump. AE82's didn't suffer from fuel surge in factory form as far as I'm aware?
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    Auckland
    Surge is not an issue on the road. But when you want to take it around a race track thats a different story!
    Now 9AGTE 410kw atw
    May 2010
    TAS
    Great info everybody
    I plan on attacking the chicken twisties with this car so I think I will go with my original plan of a swirl tank fed by the stock pump and most likely a Bosch 044.
    I will look into the Fuellab pressure reg also Bazda.
    perth
    im running rx7 550's at 60psi at full boost (20psi) with a aeromotive regulator.
    1 carter low psi high flow lift pump
    1 044
    surge tank
    this will supply fuel for 400hp at the treads.
    040 and 044 arnt the same, 044 flows more.
    Jul 2007
    o rry? according to whom? my parts supplier and the bosch website both say they have identical specs.....
    perth
    according to my bosch supplier.
    Jul 2007
    hrm, so one of our suppliers is wrong
    perth
    haha yeh.
    im pretty sure the 044 is bigger, ive always known it to be.
    http://apps.bosch.com.au/motorsport/.../fuelpumps.pdf
    Fairly different specs. I use an 023 instead of an 040.
    Not trying to be a Carport Converter
    Jan 2009
    Quote Originally Posted by charade_16v View Post
    rx7 550cc Injectors (direct bolt-in for 4a)
    *SNIP*
    Which 4A is that, some run top feed low impedance, some run top feed high impedence, some run side feed etc
    What wilbo666 said many of the setups mentioned are over the top. A walbro 255 will run 800cc injectors is cheap bolts in the tank and therfore fairly quiet. I use a carter black and an 044 in my race car which is over the top and it sounds like a jet taking off when you fire the pumps up, would hate to have it in a street car. Charade 16v setup sounds rediculous unless you are planing to make over 400rwkw with a 4agte.
    I run standard regulators I don't see a problem unless it starts to not flow enough and pushes the fuel pressure to high, have never seen this problem with 800cc injectors
    senn, RX7 injectors come in top feed 11mm in either high or low impedence depening on the series i.e series 4 = low, series 5 = high. if you have side feed these can usally be modified fairly easy to flow higher
    Roger
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    Quote Originally Posted by senn View Post
    Well the 550cc rx7 injectors bolted straight into my bigport fuel rail, I just assumed ther fuel rails are all the same….I was also told this by a couple of different mechanics…
    Is there a 4a they don't bolt into?
    Jan 2009
    probably the 20v ones cos they are sidefeed afaik. But there is a good selection of injectors for these too
    May 2010
    TAS
    Bought a Walbro GSS-341 intank today, decided to leave the swirl and external for later, just want to get this thing up and running.
    Went the Walbro as it was on the shelf, had a better fitting kit and was $50 cheaper than the Bosch.
    Will the stock 1.1 regulator handle just over 20psi???
    Or am I best to get a rising rate jobbie?
    fuel tuning will be a hell of a lot easier with a 1:1 reg, you wont have to deal with varied fuel pressure which also screws with dead time.
  1. Fuel system advice.
    By DLA11D in forum Tech and Conversions
    Last Post: 28-07-2009, 07:55 PM
  2. Fuel system Q's
    By benny c in forum Tech and Conversions
    Last Post: 22-09-2008, 01:28 PM
  3. fuel setup question
    By connection in forum Tech and Conversions
    Last Post: 02-09-2008, 12:39 AM
  4. fuel system - legalities
    Last Post: 26-11-2007, 05:35 PM
  5. make my 1g louder!!!??
    By rollsy in forum Tech and Conversions
    Last Post: 16-02-2007, 08:32 PM
