Yeah I think the next cruise me and Mitch should take the lead, That way we'll know you'll all be driving gently and safely
seeyuzz
river
No criticism Riverjust noting the difference of your needs and why then your rationale on the subject of flywheels is fine
we have own own version down here in Canberra....goes by the name of Mitch and the days his 3TGT sees more than 3500rpm are the days he has let one of us take it for a spin
seeyuzz
river
If your plenum is getting that hot, then it will be transferring that heat into the air that feeds your engine. Typically the IAT does include a plastic insulator by design to provide an electrical isolation (it should be a two wire device after all), which should also provide some heat isolation. I would start by directing more air past your turbo and down under the car. Remove the heat from the engine bay, and you will remove it from the intake air.
Another option is methanol/water injection. This is a very fine mist put in before the throttle body used to cool the intake air. Do some google searching on that and you should come up with about eleventy billion options on how to set a system up, from the very simple agricultural setups, to full blown race gear.
Im gonna build a 18rgu Blowtrough carb turbo just for fun, with stock bottom and top.
But i have a few questions. I have heard that i need a swirl pot, but is that necessary just to drive on Low boost?
And do i need carbs designed for pressure or can i use stock solex carbs?
A pressure referenced fuel reg for sure (low pressure referenced too which are hard to find)... But not a rising rate reg. no need for the rate to rude when feeding a carbie, just need fuel pressure increase to match boost pressure increase with around a 4 psi differential...maybe a tad more if the car is making decent power.
do I have to modify the ignition to put the turbo on a 18rg. Know its the best but do i have to do it just to get it running and movable?
okay. Thank you.
But can i adjust my ignition timing so i can drive with it like it is until i can afford msd al6, blaster coil etc.?
It'll be strong enough, it just has the wrong adv curve in it. You can adjust to get less adv overall but that will make it very doughy off boost. I just had mine rebuilt with a boost suitable adv curve.
It might be completely fine, just keep a close ear out for det as the stock pistons won't last long
