Page 69 of 74 FirstFirst ... 19596768697071 ... LastLast
Results 1,021 to 1,035 of 1105
Thread: The 18R-GTE reference manual ...
  1. #1021
    Default Re: The 18R-GTE reference manual ...
    No criticism River just noting the difference of your needs and why then your rationale on the subject of flywheels is fine we have own own version down here in Canberra....goes by the name of Mitch and the days his 3TGT sees more than 3500rpm are the days he has let one of us take it for a spin
    Yeah I think the next cruise me and Mitch should take the lead, That way we'll know you'll all be driving gently and safely
    seeyuzz
    river
  3. #1023
    seeyuzz
    river
    History of 200kph flybys suggest otherwise although not so much these days, so maybe i'll just sit at 3rd wheel
    If your plenum is getting that hot, then it will be transferring that heat into the air that feeds your engine. Typically the IAT does include a plastic insulator by design to provide an electrical isolation (it should be a two wire device after all), which should also provide some heat isolation. I would start by directing more air past your turbo and down under the car. Remove the heat from the engine bay, and you will remove it from the intake air.
    Another option is methanol/water injection. This is a very fine mist put in before the throttle body used to cool the intake air. Do some google searching on that and you should come up with about eleventy billion options on how to set a system up, from the very simple agricultural setups, to full blown race gear.
    Quote Originally Posted by jabbatron View Post
    Yeah i know what your saying. Mine is tapped directly into the stock plenum and on warm startup it can read 50+ degree's higher due to the heat from the alloy manifold soaking into the sensor. Maybe what i need is a plastic insulator that isolates the sensor from the manifold. Anyone know of anything like that off the shelf or will i be making one myself?
  5. #1025
    Aug 2008
  6. #1026
    Aug 2012
    Gaupen
    Im gonna build a 18rgu Blowtrough carb turbo just for fun, with stock bottom and top.
    But i have a few questions. I have heard that i need a swirl pot, but is that necessary just to drive on Low boost?
    And do i need carbs designed for pressure or can i use stock solex carbs?
  7. #1027
    Quote Originally Posted by devilsix View Post
    I suspect it won't be fun and if you are asking those kinds of questions this is a proj well out of your league...Not meaning to criticise, just trying to save you heartache and wasted $$$.
    Aug 2008
  9. #1029
    A pressure referenced fuel reg for sure (low pressure referenced too which are hard to find)... But not a rising rate reg. no need for the rate to rude when feeding a carbie, just need fuel pressure increase to match boost pressure increase with around a 4 psi differential...maybe a tad more if the car is making decent power.
    Aug 2008
  11. #1031
    Aug 2012
    Gaupen
    do I have to modify the ignition to put the turbo on a 18rg. Know its the best but do i have to do it just to get it running and movable?
  12. #1032
    It should be fine. Just be aware the ignition advance will be more aggressive than you will want, so drive it gently to avoid detonation.
    Aug 2012
    Gaupen
    okay. Thank you.
    But can i adjust my ignition timing so i can drive with it like it is until i can afford msd al6, blaster coil etc.?
  14. #1034
    It'll be strong enough, it just has the wrong adv curve in it. You can adjust to get less adv overall but that will make it very doughy off boost. I just had mine rebuilt with a boost suitable adv curve.
    It might be completely fine, just keep a close ear out for det as the stock pistons won't last long
    Repeated due to personal experience
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 05:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 11:00 AM
