Page 59 of 74 FirstFirst ... 949575859606169 ... LastLast
Results 871 to 885 of 1105
Thread: The 18R-GTE reference manual ...
  1. #871
    Default Re: The 18R-GTE reference manual ...
    ^^ This MMH. Once they are ready to roll, let me know, as I'll take one.
  2. #872
    Junior Member Grease Monkey MnToyGuy's Avatar
    Minnesota
    Once they are officially tested, I'll start taking orders. Machine shop time is likely going to be 4 weeks+. The nice thing about Toysport is that we can all be confident it was put through the right testing.
  3. #873
    fuck yeah!! I want some oil pump!!
  4. #874
    Minnesota
    Just stubled across this (AGAIN):
    http://www.toymods.org.au/forums/eng...-manifold.html
    So if I get an RG flange, an SR20 manifold is the right pitch? Otherwise, I'm takin a TIG welding class on the 19th. Class project?
  5. #875
    Sep 2011
    Quote Originally Posted by MnToyGuy View Post
    Is the 18RGEU TB sommon to any other engine? Is the 22RE one compatible with the RGEU plenum?
    Here's my motor prepped for turbo
    i have the identical engine to that but need fuel injection for it, it came out ith it but we dont have it
  6. #876
    22R throttle body bolts on, not sure about clearance with the cable linkages. The 22R butterfly is smaller than the 18R-G one.
    5M-E throttlebody also bolts on, linkages are on the opposite side though. The 5M-E butterfly is the same size as the 18R-G one.
    You'd have to match up the type of TPS if you were to use original EFI computer etc. 18R-G uses 3-pin, 5M-E early uses 3-pin (from memory), 5M late uses 4-pin
    22R (one version at least) uses 4-pin.
    (\__/)
    (")_(")
  7. #877
    Top End
    Hey people
    just red through all the 18rg threads cause im gunna build a nice one next year wanted to see what advances ppl have made since the mid 90s when i was playing with them
    anyway just thought id post this up in case any hasnt see it
    Its probably someone from here selling it any way but didnt see it in for sale section
    18rg Toyota Twin Cam Race Engine Car Performance Parts for Sale | $8,000 | QLD: Brisbane - Boostcruising Classifieds
  8. #878
    Yellow KE20 running 9's - that gets my vote.
  9. #879
    Top End
    well at first i thought it was you but all the number didnt add up so ???
    either way impressive and can have a vote from me also
  10. #880
    Minnesota
    Brad, EFI setups are as rare as fat Japanese. Expect to pay in the range of $800 for a complete setup. The other route is ITB's and extrude-a-rail with MS ECU. That'll run you about $1200.
    Steve, here's the solution to a 5M TB:
    I've been e-mailing Toysport weekly about the pump and no reply since the last post.
  11. #881
    In Aus, a complete EFI set should set you back around $300, then it is wise to replace the injectors and do a few other niceties while you are at it.
  12. #882
    Minnesota
    Looks like it may be a while before Toysport can test the pump. This from a thread on 1st Gen Celica:
    Anyone heard from GroupB lately? He and I have business to conclude and I haven't been able to get a hold of him for a while. I've tried phone and PM and no luck. Suggestions?
    From what I have heard Joel's father in law is very ill back in Philippines
    and he’ll should be back by the end of December.
    He did post something on here yesterday though.
  13. #883
    Top End
    would have been a nice score cant believe they still turn up unused
    TRD - Unused! 18RG engine oil pump - Nengun Performance
  14. #884
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Quote Originally Posted by o_man_ra23 View Post
    Are you talking about a 22re mani?
    I have one I bought of Undah Presah but it is set up for mechanical injection. [IMG][/IMG][IMG][/IMG]
    I'm thinking its just going to be easier to get a stock mani and fuel rail to mock it all up...
  15. #885
    I bought a full stock setup including injectors, loom, manifold, TB, rail and the proper RGEU thermostat housing for $300 plus freight. It wasn't a 22R manifold. It is currently sitting in a bucket in shiny sandblasted pieces next to the fresh motor which is on an engine stand in my shed...
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 04:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 10:00 AM
