Results 1 to 15 of 28
Thread: Dry ice, sound deadning removal
    Default Dry ice, sound deadning removal
    Hi all quick question, I'm looking to remove the sound deadning from my ae86 race car, but I'm having trouble getting my hands on dry ice. My local boc recon they don't deal in it. Anyone have any sugestions where to get it on the northern beaches?
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    Eltham vic
    Default Re: Dry ice, sound deadning removal
    hi craig
    with the club car ,we found that by leaving it out side on a cold night can have close to the same results
    then with a variety of chisels including a brick bolster and an air chisel ,and a rubber mallet to crack it , it came away fairly easy
    we saved 14 kg of deaden er
    Not all BOC branches carry it, closest one would be alexandria near the airport that im aware of.
    Personally I think the dry-ice idea is not really that good. I tried dry ice for one section and then used a heat gun for another section.
    I found that the heat gun was easier and you had less chance of marking the underlying metal (if that is a concern) - then a quick wipe up of the slight remaining material with wax and grease remover and you are done.
    works out to be cheaper and easier to get your hands on a heat gun as well - which you will probably use for other things anyway!
    I got my dry ice from here - http://www.airliquide.com.au/
    Blacktown one has it, bring your own esky.
    Aug 2009
    hi craig
    Yeah, Ian is right, the cold overnight temps makes it as good as and less messy. Hit it with a mallet and use a 30mm chisel with the corners rounded of makes it easy. Then once all the chips are out, hit it with w wire wheel on a drill to clean up the residue.
    Rgds, Willofan
    Penrith BC
    go to a pathology collection place (blood collection etc) at the end of the day, and ask for whatever thy are throwing out
    ../delete/ban
    tech moderator
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Quote Originally Posted by ed_jza80 View Post
    Hope you're referring to the Ice there
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Sweet so many sugestions! Haha, I can't realy leave the car outside as I live in a unit and I'm not sure if would still be there in the morning! I will definatley try the pathology option, otherwise I guess it's a drive to the airport or out with the heat gun, we used the heat on a mates e30 and it wasn't much fun, hence wanting to try the dry ice approach.
    Cheers everyone.
    Ps, rep all round but I accidentaly clicked neg for you cuzzo, ill find another post and make it up.....
    1.24 @ oran park GP
    hi craig
    that may be the way it works in Melbourne, but your nights are a good 5-8 degrees cooler than ours unless you are talking way out western suburbs of Sydney.
    Junior Member 1st year Apprentice Trev084's Avatar
    an air chisel
    x2, took me 30 mins to strip the sound deadening from the front and rear seating of a 300zx with an air chisel.
    i vote dry-ice. I applied it in sections and ensure the ice was covered with newspaper & cloth to minimise evap losses and keep temps down to a minimum. After 10-15 minutes, shift ice to new section, a fews belts to the now-frozen section with a hammer/mallet, clean up with dustpan+brush, have smoke+coffee and read a few pages of the paper. Repeat.
    No noise, no scratching, no odour - plus i got to blow up a few 2l coke bottles afterwards.
    No noise
    Silenced hammer
    Sep 2009
    I used liquid Nitrogen,
    Worked a treat, i think it was about 6 liters did a ae92 hatch completely and it probs only took half an hour.
    Pro's:
    BOC and most other stores have it,
    Doesn't cost to much when you weight up how long it takes compared to CO2
    About twice as cold as dry ice
    Con's:
    Will Freeze limbs (like solid frozen digits are cool anyways), must be very careful.
    Have to hire an urn to transport it safely.
    harder to apply in a sense, i had a stainless steel bucket that i would just tip about 500ml in at a time and tip that in over the sound deadener.
    *protip: probably dont transport the urn with it in your front seat with a seat belt over it (i probably didn't think it through, much)
    Quote Originally Posted by Trev084 View Post
    Silenced hammer
    hah ... certainly quieter than air-compressor+air-chisel+floor-as-big-drum
  1. Quick and Easy Sound Deadener Removal - A Pictorial Guide
    Last Post: 03-10-2011, 06:56 PM
  2. Citrus solvent for sound deadening removal
    By RA23 in forum Tech and Conversions
    Last Post: 10-10-2008, 05:39 PM
  3. 1GGTE metalic sound pinging inside engine !
    By romelan in forum Tech and Conversions
    Last Post: 27-06-2006, 02:23 AM
