tried just doing a custom plenum? or even just a plenum 'cap'
Car is a 90 Celica GT-Four with a 3sgte
Heat Wrapping a Ceramic coated manifold???
I've heard a few people say its a bad idea because the ceramic coating coating starts to come off the manifold and get absorbed by the heatwrap. But im not entirely happy with the heat coming from it.. its great but i still want less radiant heat. unfortunetly my fmic piping goes over it as part of the cold sidebut i am trying to work out a side feed for it.
Custom manifold heat shield?.
because it is custom i couldnt use my stock heat shield so now its just exposed, but ive seen people use some kind of silverery material as a custom heatshield. anyone know what it is? where to get it? links?
Mild Steel
I've heard from a guy that does a bit of track work that mild steel can crystalize and break when heat wrapped with track temps.. i plan on doing track days. anyone heard of this?
Alternator.
When using the stock system there was an alternator insulation shield and an air intake to it. but the custom manifold meant that i couldnt use it. now its sitting within a couple of MMs without the heat shield. Im thinking of using the heat insulation silver tape?? i dunno where to get it but ive seen people use it on the bottom of their TMICs to keep the temp down.
Intake piping
Does heat wrapping it actually keep it colder? or would it keep the heat in a bake it??
Thank you for enlightening me!!
90' GT-Four ST185 RC motor ST205 gearbox!
New installs Ct20B and Rear Strut Brace!!
Next to come;
3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
got the 3sge side feed. just have 2 work out idle control..
Next to come;
wrapping coated manifold (exhaust?)
depends on the coating, and how hot the manifold gets. some shit coatings will fall off.
heat shield
use that ACL stuff, like used on the turbo falcons, awesome stuff.
mild steel
bullshit. mild steel is already crystallized
alternator.. yeah your alternator is going to get rooted. you NEED a heat shield.
that aluminium tape does buggerall for serious heat
wrapping intake
it depends what temperature is inside and outside.
^ ^ what OC said. using the XR6 turbo falcon shield stuff will definitely help - plus it's nice and malleable.
I'm in the same process as you. Do you have a CAI?
the falcon stuff is ACL branded and can be bought in 600*300mm packs from autobarn, bursons, autopro etc
As others, use that ACL stuff to cover the manifold & also to make up a heat shield between the dump pie & the alternator.
Wrapping is designed to keep the heat in, which also keeps the exhaust gas speed up, helping turbo spool. How much it helps is a well discussed topic.
I've work out a way to get the alternator duct back on. These have gotten progressively longer over the various 3S models. ie the Caldina one actually ducts all the way into the inner guard.
Intake: wrapping it generally will keep heat in, which is what you don't want, but if it's passing by things that are hot (turbos, exhausts), then you don't want that heat coming in. But again, a heat shield in this case would probably be better than wrapping it.
Look at heat shielding brake / clutch / power steering reservoirs to!
Originally Posted by S2K
yeah.
Running RBF600 brake fluid and still boiling it is an annoying and expensive exercise![]()
My engine bay:
The heat shield is made from the ACL stuff you can buy at Supercheap.
My dump pipe is wrapped with exhaust wrap and then sprayed with VHT exhaust paint.
The alt is the stock one with the front cut off and more aluminium tape added.
All seems to do the job.
Daily: Toyota '05 Rav4 Sport
Just a quick 30cent upgrade to get heat down is to pack your bonnet bolts with washers...(might need longer bonnet bolts) give the bonnet an inch or so gap so it doesn't close flush where the hinges are...
Did this on my mates R32GTR you can watch the heat pouring out after a hard hoot..![]()
"Don't worry what people think, they don't do it very often."Originally Posted by oldcorollas
yeh that ACL stuff is what im after.. how much it go for??
draven. i have a cold air intake but need to box it, so hot air intake lol..
so wrap mild or dont wrap?
thanks guys
Next to come;
ACL shield was ~$40 for a big piece... enough to do mine with some left over.
