If you're in sydney, there's a mob called "Competition Coatings" that do ceramic coating. I got most of my engine done and it's done wonders for underbonnet temps. I took my car for a good thrash today in the 30 degree heat, and my temp didn't budge from one below halfway the whole time. The tripple core rad probably helps too... and the airbox.
I'd probably look at a CAI & airbox before you go ceramic coating though.
			 Underbonet & Intake temps
 I wasn't intending on running cold air from the aircon into the airbox(although, not a bad idea, but definately not worth it), I was just meaning ducting air from the front vents using that very bendy aircon ducting you can get from hardware house.
			 ) to sit between the extractors and the intake pipes.. sayy.. two 0.5mm thick aluminium sheets, with a cm or so airgap between them... that will stop the extractors directly heating the intake pipe...
