Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Keeping my underbonnet temps down. plenty of Qs.
    Default Re: Keeping my underbonnet temps down. plenty of Qs.
    I mentioned getting a CAI sorted, by which I hoped to also imply boxing the pod
    Quote Originally Posted by Draven View Post
    My apporogie
    So.... if you attach insulation under your bonnet, will this make the engine bay temps higher? On Trini my bonnet gets very hot. I'm getting the manifold, turbo housing and dump pipe ceramic coated, which should alleviate some of the heat. I'll probably get some form of heatshield done for protecting the air-con compressor and maybe the alternator.
    seeyuzz
    river
    Tasmania
    Quote Originally Posted by Duk View Post
    This doesn't work. When the car is actually moving, there is a higher pressure at the base of the windscreen. Potentially air could flow into the engine bay via the gap at the back of the when the car is at speed.
    Car manufacturers do have a pretty decent idea of how air does and doesn't move around the car and thru the engine bay.
    All of this talk about reducing heat in the engine bay and nobody has suggested he do anything about that pod filter that is directly behind the radiator
    hence why i havnt done any of that but some people think its the way to go.
    1973 TA22
    Quote Originally Posted by Cuts View Post
    But doesn't suggesting it perpetuate the myth
    Jun 2009
    That isnt my car mate lol.. my pod filter is as far to the side of the engine bay as possible.. its touching the sidewall.. and has a 2.5" fexipipe pointing right at it from where the fog lights normally go.. plus the metal part of the intake is atleast 15cms away from the turbo, so that will reduce some radiant heat on the metal..
    i was gonna remove that rubber plastic weather strip on track days.. but normal driving id prefer to keep the water out of my coil and ignitor.
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    Tasmania
    it was mearly an alternative to bonnet spacers, i never said it was a good idea.
    1973 TA22
  1. 1JZ engine temps vs 18RC engine temps
    Last Post: 12-04-2008, 08:03 PM
  2. 180 Degree temps and driving..
    By Matt-AE86 in forum Tech and Conversions
    Last Post: 04-12-2007, 05:42 PM
  3. Air Conditioning Temps
    By ProjectSleeper in forum Tech and Conversions
    Last Post: 15-10-2006, 11:04 AM
  4. Underbonet & Intake temps
    By Alchemist in forum Tech and Conversions
    Last Post: 09-12-2005, 03:56 PM
