Results 1 to 15 of 21
Thread: 4agze head gaskets??? where???
    Junior Member 1st year Apprentice fatRA28's Avatar
    Aug 2006
    Default 4agze head gaskets??? where???
    Im still having trouble finding gze gaskets, hopefully metal in stock size 1.2mm. They all seem to be larger or smaller in thickness. Im not sure what sizes are ok to just put straight back on without making any changes to things. please leave links or suggestions.
    thx
    Aug 2006
    Default Re: 4agze head gaskets??? where???
    Also, all the vrs kits i`ve seen don`t seem to have the small washers that go under the bolts on the top cover etc, mine are unusable.
    Mar 2009
    Just go Toyota genuine mate, the gasket wont be metal but it will be the correct thickness. This site http://www.toyodiy.com/ has just about every Toyota part number you could want (its where i went 4 all my 4agze rebuild parts).
    Besides, unless ur engine will b running very high boost u shouldnt need 2 go with a metal head gasket.
    GZE Love Grease Monkey PsyCo's Avatar
    Jan 2009
    There's a company up here in QLD called SERCO that make custom gaskets (metal/copper ect) to order. It ain't cheap though.
    second the toyota genuine. When your there grab some new headbolts and the washers you require
    Past - 3 RA23's 1 TA22 - Hairdresser mobiles
    Present - Red 4age KE70 - Sideways shopping trolly
    Future - White KE70 - Grandma shopping trolly
    Jan 2007
    queensland
    a genuine AE112 7afe h/g
    there MLS (just over 1mm think) from what i have read.. can someone confirm??
    if you call toyota spare parts they would be able to tell you hopefully..
    Jan 2007
    queensland
    how much was skimmed on the head? that would give you an idea on how much you need to compensate with a h/g..
    having said that.. putting a .8mm TRD in there isn't exactly going to hurt it.. it would be like running an extra 1.5psi boost 'all the time'
    wa
    road and track have some cometic ones in stock atm
    http://mrtwo.mine.nu/topic.asp?TOPIC_ID=19006
    queensland
    the metal 7A gaskets don't suit a 4AGZE. The cooling jacket holes are totally different.
    Road & Track have most in stock. www.roadandtrack.net.au
    perth
    dont be scared of the genuine 4agze h/g, they hold down pretty good.
    put it this way, a genuine hg on stockish 4agze is over kill
    Jul 2007
    a 4agze head gasket is the same as a 4age head gasket. if you cant find a 4age head gasket you dont belong near an engine.... or you live in like alice springs or something
    Sep 2009
    A+
    There is no difference between the 2, As compression is lowered from the factory via the pistons.
    Aug 2006
    Well, as it turns out, toyota in wollongong were useless to talk to, albion park was able to help me, got some goodies from japan for me, eg 2 only front engine mounts left in japan for my particular model. All the gaskets i ordered had no metal whatsoever so sent them all back, genuine toyota one is great. there were many gaskets , but they were all crap.
    As trdee said"if you cant find a gasket you dont belong near an engine" the problem is seeing one before you order it online, to see how crap it is. most are.
    thx though people, some of your replies helped. cheers.
    Low rep 1st year Apprentice
    Feb 2010
    western australia
    you can try Fensport.com in the uk
    Oct 2009
    A 1mm gasket will be fine if you want to raise comp go for a 0.8mm and to lower go for a 1.2mm depends on how much boost you want to run
    edit also you can get them from
    http://www.tweakit.net/shop/index.ph...24ngr756fib9l1
    http://www.rhdjapan.com/toyota/ae92-...o/head-gaskets
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  3. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 10:15 PM
  4. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
