Results 1 to 12 of 12
Thread: 4agze ERROR CODE HELP ??? 52 i think.
    Junior Member 1st year Apprentice fatRA28's Avatar
    Aug 2006
    Default 4agze ERROR CODE HELP ??? 52 i think.
    Can anyone point me in the right direction for a chart of some sort please?
    1989 ae92 trueno sprinter gt-z, 4agze AFM.
    As i havn`t done this before, im thinking the error code is 52. After the 5th flash of 0.5 sec intervals, there is a 1.5 sec gap, 2 more flashes , then it repeats.
    The engine warning light is coming on every time i go over 2800 rpm.
    Any help or tables for this engine would be great.
    Thx.
    Gearwhore. Backyard Mechanic
    Oct 2008
    Default Re: 4agze ERROR CODE HELP ??? 52 i think.
    52 is Knock Sensor, which would definitely make sense.
    What fuel are you running? GZEs require 98, at least.
    Aug 2006
    yep, only ever run 98, the thing is, just done a HG on the car, so wasnt sure if the CAS was in the exact position.
    I do recall though, the green plastic clip on the knock sensor was seperated from the metal part of the nut, not knowing how delicate it would be, just put selastic around the edge to seal it on, however im pretty sure it is meant to be one piece.
    Is the 4age sensor possibly interchangable with the gze? Im wondering if it will be easy to source?
    Nov 2009
    Tas
    pretty sure a 4age dosnt run a knock sensor only 4agze.. 3sgte would most likely be the same.
    Owner built, tuned and driven. 420kw 9000rpm 3sGTE AE86 Levin
    The 4AGE does have a knock sensor. I had the same error code coming up a few months back on my AE93 (same as AE92). The sensor was $240 from Toyota.
    Also worth checking is the wiring coming out of the sensor as it may be damaged enough to give the error. The error is the knock sensor not being detected if I remember correctly, so a damaged wire could easily cause it.
    Oct 2008
    Quote Originally Posted by s14seriesII View Post
    AFAIK Bigports don't, everything else does.
    Chiba
    3SGTE isn't the same, but any 4A knock sensor can be used, just the plug changes, so if you get one from the wreckers etc, make sure you snip the plug off the loom as well.
    Also:
    http://www.twincam.info/index.php?showtopic=40803
    Aug 2006
    Awesome guys, thanks so much for the info and help, cheers.
    But foook,lol, $240 for a bolt with a wire from toyota is a bit steep huh? Thats crazy hahaha.
    Aug 2007
    you think thats steep, genuine 4agze are just over $300 lol......
    Quote Originally Posted by the_random_hero View Post
    I have to check my AE82, but I think it's only the 3-rib bigports that don't have it - the 7-ribs I believe do.
    Aug 2006
    yeah, i think ill just look for one off a 4a somewhere, wreckers etc, and worry about the plug when i get too it,lol
  1. 4agze build questions
    By ae86boy in forum Tech and Conversions
    Last Post: 06-11-2011, 02:59 AM
  2. 4AGZE Compression Advise needed
    By _FNQ_rolla_ in forum Tech and Conversions
    Last Post: 26-10-2008, 08:25 PM
  3. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
