Results 16 to 20 of 20
Thread: Diff Ratio Calculations
    Default Re: Diff Ratio Calculations
    Man ADM T series diffs aren't the strongest I suggest getting the YR22 F series diff, I think they are actually 40mm wider then a T18 one. You can get 4.566:1 or 4.8:1 ratios easily from the front diffs of some hiluxes/4runners.
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    The following Image is a graph of 4.1/4.778 and 5.71 ratios with the stock T50
    as well as one of the albins gear sets for good measure (4.1 diff ratio)
    The 5.71 puts the meat of my revs in second right where I recon I need it
    Old school jap. thats the one I meant, I got plenty of room for 20mm wider each side as I dont need wide wheels
    AL510: makes sence
    Heres the video from the weekend
    http://www.youtube.com/watch?v=wIMzcthNxds
    You can see the trouble with gearing im having, cant get the right gear coming into the corners
    Still wrestling around with Diff Ideas for my car.
    Im going back to T-18 struts & hubs with 1.5deg camber bent into the struts with volvo disks/calipers which puts the track on the front back to standard + around 7mm for the disks. which makes moving to a 40mm wider diff a harder decision as Id rather be able to use the same wheels all round the car
    I did find this little puppy:
    http://www.zenky-racing.com/shop/cat...store=francais
    http://www.aeu86.org/viewtopic/ae86/...er=asc/start=0
    550 euro delivered anywhere from europe, apparently ships from thailand so I guess it would be a similar price to australia according to googe thats around 850 AUD + fitting :S
  1. diff ratio options for ke70
    Last Post: 01-07-2009, 03:44 PM
  2. Replies: 9
    Last Post: 18-04-2007, 08:39 AM
  3. rt132 corona diff ratio?
    By dundee230966 in forum Tech and Conversions
    Last Post: 21-02-2007, 10:31 AM
