Results 1 to 4 of 4
Thread: rt132 corona diff ratio?
    Default rt132 corona diff ratio?
    I have a corona lift back and was wondering if there is any way that I can cut the revs down ???? At a 100k I am currentl;y doing 3000 rpm in 5th gear. Is it possible to play with the diff ratio to drop my revs at all? I know that this model came out with a 3.9 and a 4.1 ratio. Any idea which one of these will drop my revs? It would be the ducks nuts if I were able to pull the old girl down to something like 2500 rpm at 100k. I have herd down the grape vine that a diff out of a lux will also fit and they have a ratio of 4.5. All means crap to me so can some one please fill me in.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Default Re: rt132 corona diff ratio?
    Manual RT132 had a 3.9 T series diff, Auto had a 4.1.
    The higher the number, the more revs at 100km/h, so a 4.5 is a backward step!
    You might be able to find a taller diff (lower number eg: 3.5) but I can't suggest a suitable source.
    tasmania
    i don't reckon you'll have much luck. you have a T series diff, they were only put behind smaller engines, ie not really suitable for tall gearing.
    you'd be better off getting bigger wheels( rolling diameter i mean. i'm not saying you should get fully sik chromies )
    bare in mind, that this may cause guard rub, and it'll put you're speedo out.
    beer me!
    Yep, my manual RT132 has the 3.9:1 gears. T312 is the code IIRC. 3000rpm at 100kms isn't too bad though I don't think. I would just stick bigger wheels on as was said as it will be much easier than finding a diff (if there is one). Search for toyota axle database and have a look through there.
    QUICKEST 1JZ'S IN OZ
  1. changing the gear ratio's in hilux diff.
  2. Diff Ratio Good Link
    Last Post: 13-10-2006, 06:55 PM
  3. Diff change in RT104 corona
    By lightning in forum Tech and Conversions
    Last Post: 23-09-2006, 12:42 PM
  4. RT132 Corona - T Series, diff noise?
    By bnicho in forum Tech and Conversions
    Last Post: 27-07-2006, 11:18 AM
