Results 1 to 11 of 11
Thread: diff ratio options for ke70
    Default diff ratio options for ke70
    hi all just wondering what if any other diff ratio options are available for a for a ke70?? I know the manual is 4.1 and auto is 3.9 but is there any other ratios out of other corolla's that will fit? Reason im asking is i have a auto ke70 wouldnt mind something a bit better for highway use so its not revving its tits off doing 100kph.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: diff ratio options for ke70
    anyone? wasnt there a corolla that came out with a powerglide? what was the ratio on that one? i have searched but couldnt find much
    12.4 @ 110mph
    New Zealand
    Assuming that you have the Jap spec housing in Oz look to NZ for late model KP Starlet diffs, think 3.3 and 3.5 available? Just be sure it is from the U code diff not the smaller X code.
    Callum
    just fit bigger rolling diametre tyres......im assuming this is a daily shitter......?
    most likely will be aussie bog warmer p00 diff.
    fit 4age - it will be cheaper.
    Drive Grease Monkey
    Feb 2009
    S.A
    Quote Originally Posted by Jordan 76
    Its the other way round mate, the auto's have 4.11, the manuals 3.9
    If you can find a t18 t series diff, most had 3.7 ratio's.
    Given that your car is 1300cc and the auto box has 3 gears, its not a good recipe for highway cruising.
    The reason that its revving its head off with is because it needs to have enough power to keep it at 100!
    do t18 diff housing's bolt up to a ke70?
    12.4 @ 110mph
    New Zealand
    Bolts up to the body but you will need to change the driveshaft.
    Callum
    will i have to shorten or lengthen the shaft or just the flange at the back?
    12.4 @ 110mph
    You can just use a T18 tail shaft if you're running a 20 spline gearbox. K50s and series 1 T18 boxes are 20 spline. Either that or just using the rear half of the T18 tail shaft if your current tail shaft is a two piece.
    Toyota Hoarding Grease Monkey squish_m8's Avatar
    Sep 2008
    IMO it not worth messing with your diff ratio unless you're planning on doing something power wise to the engine.
    to go anything other than the ke70 diff's your gonna have to replace the rear end (drum to drum/disc to disc) probably either s-series or t-series from other corollas ae71/ae86/te72/te71 etc. then you will probably going to need a different tail shaft to fit
  1. Aftermarket diff ratio for GX71
    By gx71_chaser in forum Tech and Conversions
    Last Post: 30-11-2008, 02:41 PM
  2. diff ratio selection
    Last Post: 08-01-2007, 09:10 PM
  3. 4.5 ratio for t18 diff
    By Evan in forum Tech and Conversions
    Last Post: 01-02-2006, 11:50 AM
