Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: 1UZ oil filter mounting options
    Default Re: 1UZ oil filter mounting options
    Yeah, a rolled lip is all I was meaning. You may not be able to pull them off, but once it's been heat-cycled and had hot oil pumped through it under pressure, who knows exactly what it's going to do. Besides, you might just be puny
    Yeah, I must just be not strong enough hey? Hehe.
    I'm figuring a rolled lip will probably do the job, think I might go get myself orgynized with that...
    Facebook | LinkedIn
    Considering intercooler hoses can blow off at 30psi or below i guess that suggestions wouldnt be such a bad idea.
    I've had intercooler hoses blow off at less than 20psi even with a lip. The setup pictured above is 100% guaranteed to fail, maybe not immediately but definitely soon.
    Proper barbed or AN fittings are the only way to go with oil hoses. I've had an oil hose pop off before and you'd be stunned how quickly the sump is pumped dry, even with the engine idling. If it happens at full noise your engine is toast before you even realise something is wrong.
    Jul 2008
    I would weld or silver solder a nipple to the steel section and then use an an fitting.
    Al.
    Spent the money and get this done if you want to keep that setup
    yeah, I'll get that done...
    Facebook | LinkedIn
  1. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
  2. 1UZ auto box options
    Last Post: 11-02-2007, 08:33 AM
  3. Pics needed: 1uz oil filter / air con fittement
    Last Post: 11-09-2006, 02:48 PM
  4. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 13-03-2006, 11:35 PM
