Results 1 to 13 of 13
Thread: Oil Filter Interchangability
    Canada
    Default Oil Filter Interchangability
    I haven't come across anything listing oil filter interchangability.
    I just bought an oil filter for my 20v, from the local official Toyota authorised parts center.
    They supply the "Drivejoy" brand.
    On the box there is a fairly complete interchange list that applies to this filter.
    Perhaps we could provide DOCUMENTED reliable source interchange lists for filters that fit Toyota models.
    Please note, as indicated, this filter applies to 1990 m/y up 3SGTE.
    DO NOT USE THIS FILTER ON A 3SGTE as fitted to an ST165.
    If desired, the images can be translated.
    Please only post documented and verifiable interchange lists for oil filters.
    Default Re: Oil Filter Interchangability
    as long as the oil filter seals on you can use whatever oil filter you want to...
    absolutely wrong!
    oil filters are slightly more complicaded than than, there are (at least) two other things to
    consider.
    pressure relief valve
    anti drain back valve.
    for example, i was looking at a mate's 2 dollar SR20DET filter and it had an integral pressure relief valve, wheras my 4AGE filter doesn't have one, as the overpressure valve is in the block.
    Classic Not Plastic Domestic Engineer ace's Avatar
    Whenever you go to your local Supercheap Auto or repco look it up in the books on display. Depending on the brand of the book (for example Ryco) they'll have a cross reference chart that explains which oil filter in another brand (for example Valvaline) that will fit the same engine.
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    What is your Toyota Authorised parts dealer doing selling you non Toyota parts?
    and size... some filters just don't fit
    Oil filters are one thing that you should never skimp on, and you should never try to interchange between part numbers. Use the part number designated for your car, and for a whole $10, get a genuine filter. Never forget seeing a 2nd hand oil filter for sale at Cash Converters for $5. That made my day.
    RM.
    Junior Member 1st year Apprentice devolutio's Avatar
    victoria
    10 bucks? try 17 plus GST (for 4age that is)
    http://www.vicdrift.com -> drift practice and competitions at winton raceway. dates and details are on the website.
    Sorry, I'm used to trade prices But yeah, for something that stops your engine eating itself alive, they're cheap. Also, use good oils. It's like $15 pod filters...is it really worth trusting 2k worth of engine to a chinese filter?
    RM.
    [BNS70Y] + [BNS20Y] Backyard Mechanic
    Exactly right...
    Everyone spends big on the car and doing it up, why skimp out on a $20 filter when it could save you thousands???
    Ben...
    Canada
    Quote Originally Posted by Joshstix
    It is a "Toyota" part:
    http://translate.google.com/translat...y/outline.html
    Check where the capital for the company came from.
    So what happens when you get a relocation kit and change it to another more common and cheaper filter?
    SHE LIVES!
    Good question. I guess you'd have to make sure you bought a top-line oil filter with an anit-drain back valve, but also that your relocation kit had the pressure releif valve built into it. Interesting point...
    RM.
  1. 4age oil filter thread
    Last Post: 11-07-2008, 05:54 PM
  2. 2s-c oil filter assembly tread size?
    By sam-131 in forum Tech and Conversions
    Last Post: 27-01-2006, 01:24 AM
  3. Full flow Oil filter relocation line thickness
    Last Post: 02-01-2006, 05:21 PM
