Results 1 to 15 of 17
Thread: battery light coming on at higher rpm
    Dec 2009
    Default battery light coming on at higher rpm
    This problem happened to me a while ago but I can't remember what I did to fix it. My 1992 celica SX above 4000rpm ish will display the battery light intermittently.
    Any quick fix? I thought it could be the voltage regulator, would this affect the performance (of the amazing 5sfe powerhouse ) at all?
    ZZT-231 Toyota Celica SX
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Default Re: battery light coming on at higher rpm
    Yeah it sounds like your regulator is over charging
    Just replace it you should be fine
    If you dont it'll overcharge everything and you could fry something and that could get very expensive
    Apr 2007
    wilcannia NSW
    it might not hurt to put a multimeter on you battery. then rev it up and see what it does.
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Also check your battery water level can cause problems.
    Apr 2007
    Check all the above, but also have you checked how the fan belt is in condition & especially tension wise ..
    Dec 2009
    Thanks for the replies, i'll have to check the condition of the battery water level too.
    I haven't had the car long but did notice the belts did have some cracks (something i'll get onto asap) but they do seem like they are tensioned enough.
    A regulator is a pretty cheap fix on these alternators so i'll get onto that asap.
    Would this problem effect the overall running of the car in that rev range?
    Junior Member 1st year Apprentice Mr89Cressida's Avatar
    Mar 2009
    New South Wales
    Hi
    I think you need your alternator rebuilt, most likely its the brushes, but no auto elec (including myself) will pull it off just to do that, to much of a big job and cant give warrenty, you have a nippon denso alternetor so they very rearly overcharge....
    Hope that helps
    I Dont Care How Fast It Is There Is No Joy In A Diesel...
    MX83 7M-GE Turbo 280Kw@rw 7psi
    If Its Broken Use A Cable Tie...
    Subaru Legacy B4 Twin Turbo
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    Why do you consider it such a big job when its 2 bolts to remove the alternator and a couple of screws to pull out the armature to look at the brushes?
    You cant get much work as an auto electrician if all you know how to do is change fuses.
    brushes are near end of life, check voltage at revs.
    inspect, replace.
    Mar 2009
    New South Wales
    Quote Originally Posted by DrNick View Post
    There is a bit more to it then that, at least half hour to get it out and to do a proper job you need an hour to reco it, unless you want to be dodge and just change brushes, if an auto elec does that, good luck to him but im sure he will go bust soon.
    Dec 2009
    I work at a auto parts store and we sell the regulators/brush set quite a bit with no worries
    The armature won't always be worn though?
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    Mr89 is right an auto electrician is always going to reccommend a reco over just changing brushes as they will see it as delaying the inevitable. That said if u want a quick fix brushes and reg do it yourself not a hard job if u have even the slightest amount of tech savvy.
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
    Dec 2009
    Quote Originally Posted by eeeyan View Post
    I guess in the same principles they may replace the whole engine as a delaying the inevitable too lol, extreme case I know lol. Regulators are nice and cheap (compared to an alternator) so i'll give that a go.
    Recos are usually not much better, I had a reco alternator in one car and it lasted just over 1 year. New alternator wasn't much more.
    Thanks for your help everyone
    Mar 2009
    New South Wales
    Quote Originally Posted by trd_st184 View Post
    I cant say for all auto elecs mate, but my reco's run for lot longer then 12 months, and comparing a engine to an alternator and delaying the inevitable is just stupid mate as they are 2 different things...
    p.s the slip ring would be worn on a nipon denso alternator 100% and regs arent the problem...never are...
    Quote Originally Posted by Mr89Cressida View Post
    i'd be listening to the auto-elec on this one
  1. blue phosphurous stuff from leaking battery
    Last Post: 21-07-2008, 08:15 PM
  2. 3SGE alternator into RA28 charge light issue???
    By RA23_Procrastination in forum Tech and Conversions
    Last Post: 03-04-2008, 01:08 PM
  3. VZV21 - 'charge' and 'lights' light coming on
    By pAuL in forum Tech and Conversions
    Last Post: 09-05-2007, 02:33 PM
  4. Charge light is on? Overcharging - VOLTAGE REG?
    By highrolla in forum Tech and Conversions
    Last Post: 23-04-2006, 08:53 PM
