the light light means a light is out somehwere could be break light , park light etc, charge light check that the alternator is producing power when the car is running with a multi meter,it should be around 13.5 volts on idle, as you rev the motor in neutral the car voltage should rise up to around 14.7volts.... if it goes any higher the regulator is busted and needs to be replaced.
