Results 1 to 6 of 6
Thread: W58 leaking
    working hard Backyard Mechanic
    Default W58 leaking
    Hey guys ive recently changed my clutch setup in my car ae86 , Ive put it all back together and have came across a oil leak problem. Ive got oil all on my clutch fork , boot and it leaks out onto the bellhousing from the window.
    It seems to be my gearbox oil leaking but from where and how is it getting up to the boot area ?
    Ive never seen this before so if anyone could help thank you , worried its going to get onto my new clutch and start slipping
    Cheers Reece
    Default Re: W58 leaking
    Front gearbox seal / front bearing retainer cover leaking?
    Sounds like a pull the gearbox job regardless.
    Wilbo's JZA80
    Wilbo's JZZ12
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Sounds like the input shaft seal or the retainer gasket as Wilbo said. Box out.
    Nov 2007
    IF you are sure it is gearbox oil, then it must be the front seal really..
    Otherwise it could be your rear main leaking onto the flywheel and flicking it up into the bellhousing...
    but yeah, you can usually tell the difference between to two oils...
    As above, you would need to take the box out and have a look...
    It sounds like a bad leak, and you don't wanna run that sh1t dry....
    Junior Member 1st year Apprentice tin can's Avatar
    reece
    tap a breather into the top of the gearbox mate the box is probably pressurising.
    im not a Mechanic im a parts interperter
    current project: ke70 with 3tet
    now with 114kw on 10psi
    Quote Originally Posted by tin can View Post
    reece
    All the W boxes I have seen would breathe an ample amount through the shifter pivot, it's not sealed at all, just baffled to prevent oil coming out.
    My KE25 thread
  1. W58 Version Comparisons
    By medwin46 in forum Tech and Conversions
    Last Post: 06-03-2019, 09:02 AM
  2. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  3. W58 into TA22
    By fade-e in forum Tech and Conversions
    Last Post: 26-07-2008, 02:42 PM
  4. w58 with 1JZ
    By hecate in forum Tech and Conversions
    Last Post: 25-07-2008, 11:24 AM
  5. W57 vs W58
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 26-09-2006, 08:38 AM
