Yes the steel sandwich plate versions are obviously stronger since the gearset is supported by a steel plate instead of an alloy plate. An alloy plate is more likely to flex under heavy torque loads; flex = misaligned gearset = shredded gears.
Wilbo and I compared a late W58 with an early W58 and we found a few minor differences - some of the bearings and gears are slightly wider and the synchros are a different design - but the main difference in terms of strength is the steel plate.
i can tell you it wont be because of an alloy sandwhich plate
