Results 1 to 15 of 18
Thread: side mount seats & ae86
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    Default side mount seats & ae86
    hello,
    just wondering if anyone has fitted a sidemount seat to the flooe of an ae86? i just picked up a pro 2000 and want to know what people have done to make it fit.
    thanks
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Default Re: side mount seats & ae86
    anyone?????
    Penrith BC
    make a new base to mount the side mounts on
    ../delete/ban
    tech moderator
    huh?
    the only problem i see happening is that the floor of the car isn't level.so i would either have to make some kind of box section to fit it. just wondering what anyone else has done
    Penrith BC
    yeah, its not level, and its a pain in the arse. thats life
    ../delete/ban
    tech moderator
    yeh tell me about it.
    how has everyone else "legally" done this though?
    Raastler Grease Monkey
    bride rails.
    EVO's Are the Dark Side. Grease Monkey ae86trueno's Avatar
    the way my pro2000 is mounted is using the L rails then large round alloy spacers sit between the floor and the seat rail
    Because they cant use the original mount a steel plate is welded to the underside of the floor for added support, and then large and long high tensile nuts and bolts hold it all together,
    ill find a pic, it may be easier to explain.
    Ben.
    say yes to boobs Grease Monkey mc68's Avatar
    do u want it to slide or want it to be mounted in one spot?
    get some momo/bride/sparco etc etc or get a local mob to make up a set.
    bit better if its tilted slightly back anywho...
    see your engineer and ask what he will certify
    hahaha the car hasn't seen an engineer yet, but it should be ok.
    i know bride make a sliding bolt in side mount, but there a bit exxy. do any other brand make one that will bolt in?
    i had a look today and there is a few ways i can do it
    Victoria, Mt Macedon
    Slidng bases are for those that are weak.
    Weld some sections of strip and angle iron together so they mount to the factory bolt holes in the floor and give you two level sections of angle iron. Weld the sidemounts to this. Bolt seat to the sidemounts. Sit in it and enjoy.
    Hen
    PS this process takes way longer than it sounds.
    so basically your saying to make a mount to mount the side mount rails (too many mounts...)
    would height be a problem with this though?
    No. Height isn't a problem. My seat sits about as low as it possibly can at the back (almost on the floor).
    I'm 6' 5" and I can fit in a Sprinter with a helmet on.
    Basically your options are: Fork out for a brand name mount or weld one up yourself (which is a time consuming affair)
    yeah, im thinking about trying a custom one (can't hurt).
    do you know if the rail has to be mounted so that both the front and rear (on one side) connects, or can they be seperate? (so that you have 4 seperate mounts instead of 2). i know at the end of the day an engineer's word id final, but at least someone might have done this before.
    thanks for the help but guys
    edit: im thinking about trying to make the original mounts into a sliding side mount, the only problem with this is that i think the seat will sit too high. but then again, the grinder/welder is mightier than the keyboard.
  1. Arthurs seat cruise.
    By Clown in forum Victorian Events
    Last Post: 02-04-2006, 09:41 PM
  2. Seat Repair.
    By hi-ace in forum Tech and Conversions
    Last Post: 13-12-2005, 08:52 PM
