you have to make sure the flat bar is flush up against the crank so it has no leverage on the end of the bolt to bend or break it...
all good til the bolts bend or break!
i did that several times and gave up, was running out of spare bolts and patience lol
JZA70|R / 12.45 @ 111 mph.
My bolt head is roundedWill I do any damage if I belt an undersized socket onto it then weld it to the bolt head? ie. will heat on rubber crank seals wreck them. I am confident I can find enough force to crack the bolt if I can get the socket to stay on. I have another bolt to go on so im not fussed if this one gets wrecked. Engine is out of car and sump is off. I am using a hammer handle to jam the crank.
its a bolt not a nut.
i would replace the seals after welding there, in fact i personally would not weld it at all.
Never late in an x8
i made one typo i meant to weld a nut to the bolt on the crank. You shouldn't worry about the mainseal if you weld it quick on high amps.
ew bit late now. I have welded it on there. In the process of putting it back in the car. Im putting it back in the car so that the mounts hold it still while I get some leverage on it. If it spews oil out of the front seal when I start it then I will weep.
If you welded it quick on high amps you have nothing to worry about, even if it did warm up a little i doubt it would get past 80 degrees C.
How much was a new bolt worth essaysixtythree?
Most likely yes, I will spew. I was thinking that the seals should be able to take a fair bit of heat. Combustion chambers reach around 400 C I think and a fair bit of that would transfer to the block and crank. But a welding arc is around 3000C minimum I think so maybe I will be weeping more than spewing.
Anyway I got it off. Bit of extra pipe and it put up no resistance.![]()
Casey I had a spare block with bolt already removed. So it was free.
knocked this up last weekend
pretty much the same as requiem's only 40x40x5 angle
Engines looking good beatle. Wish I had more time to finish mine.
