Results 1 to 5 of 5
Thread: Difference ECU for automatic vs manual 3sge
    Sep 2009
    Sweden
    Default Difference ECU for automatic vs manual 3sge
    Hello from Sweden!
    I have a customer with a racecar Celica and an 3seg Beams Red Top engine out of an automatic car. The Celica has an manual gearbox.
    When we run the car in our Dynapack dyno the AFR went down to 10:1 from aprox 3200 rpm and up. Could this be due to the ECU (automatic) want some signal from the gearbox?
    At steady 3000 rpm the AFR was around 14.7 untill nearly full throttel when it got to 14.0.
    So the o2 regulation seems to work properly.
    Or does anyone have a clue about what's wrong here.
    Regards
    /Bert-Ola Runeson
    Sweden
    www.masensmotor.se
    Brisbane
    Default Re: Difference ECU for automatic vs manual 3sge
    Sounds like something else is missing, an AFR of 14.0 at full throttle is too lean - unless you meant redline at part throttle and rather than full throttle?
    Sep 2009
    Sweden
    Quote Originally Posted by Shifty View Post
    OK, maybe it went down to 13.0 at full throttle at 3000 rpm but definitely not 10.0 that happends with higher rpm.
    An AFR of 10.0 are utterly to rich.
    Sep 2009
    Sweden
    Dyno result.
    Any ideas about the reason for the rich AFR and low power.
    Sep 2009
    Sweden
    Problem solved.
    New MAF fixed the rich AFR, and the discovery of an faulty knock-sensor found the lost power.
  1. Manual ECU on auto loom 1jz
    By naten in forum Tech and Conversions
    Last Post: 25-03-2009, 03:52 PM
  2. 3sge efi ecu questions
    By sam-131 in forum Tech and Conversions
    Last Post: 01-09-2006, 01:05 AM
  3. ECU....all the difference
    By Alchemist in forum Tech and Conversions
    Last Post: 22-05-2006, 11:54 AM
  4. auto ecu runing manual car
    Last Post: 06-05-2006, 12:56 AM
