One thing i found that made a difference is Battery voltage correction to get stable afrs at idle , not sure if you have a adjustment on your ECU , But i ended up disconnecting the alternator to do the adjustment ,and to add the correct milliseconds as the voltage dropped ,, This gave me a stable AFR`s @ idle when the voltage varried and also helped with starting as the voltage drops when cranking,
