Results 1 to 15 of 28
Thread: Steering arms - Tapered Reaming to suit larger ball joints
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    Default Steering arms - Tapered Reaming to suit larger ball joints
    Hello boys and girls
    I am looking for somewhere in Vic that can ream out RA60 steering arms to suit a MA61/cressida balljoint.
    Everyone says its easy to find someone to do it, but ive rang a few engineering workshops and a few other workshops as well and no one can do it.
    I did some maths based on Hens measurements of RA60 bits and it seems the tapers are far from "morse" as well
    Any help would be appreciated. If anyone has done a similar conversion in vic who did your "reaming"
    Regards,
    Phill
    Default Re: Sterring arms - Tapered Reaming to suit larger ball joints
    surely someone must have an idea?
    South QLD
    This company make 2 different tapers , not sure if they are the correct
    http://www.secureperformanceorder.co...ProductID=2631
    in Aust your better contacting http://www.iboettcher.com.au/shockdoctor.htm
    and quoting the affco part number ,
    Melbourne Victoria
    try graham herring engineering in rowville he did my ra40 to mx62 lower arms ,he is in laser drive
    I'm surprised you cant find anyone. The first guy i called in Hobart did mine. He didnt actually have the Reaming 'bit' so he did it on the lathe. Charged me $40. The second set i got them to do, they did have the reaming 'bit' and they charged me $20 i think.
    well several of the places said they would do it on the lathe, but charge me for the priveledge!
    Said it was a bit of rooting around setting it all up, would be $50 a steering arm, and i need to get 2 sets done.
    Ill try the place glenn mentioned tomorow
    Default Re: Steering arms - Tapered Reaming to suit larger ball joints
    Dude! What a rip off!!! $50 a steering arm! How much do they charge an hour! Stupid. I'm glad i live in tassie. Heck i may have to wait a week to get them reamed but atleast it dosnt cost me an arm and leg.
    I had a hard time finding Graham herring on laser drive, turns out hes in the back of "Raw Imports"
    Contact details as bellow:
    Raw Performance Imports details:
    Phone: 03 9764 8422
    Fax: 03 9764 0145
    Factory 4/27 Laser Drive
    ROWVILLE
    VICTORIA 3178
    http://www.rawimports.com/hering.html
    Hes doing my arms atm, 1 week turnaround atm he seemed pretty busy
    Thanks for the help
    Finally got my arms today, took longer than expected as he is pretty busy. That said, was $15 each arm and its all good now
    Also helped me out with some suspension setup tips for the corolla
    Quote Originally Posted by gearb0x
    I've had mine for about 20 years but I'm glad you've got yours now
    Seriously though, it's good to see more people doing this mod
    hehe my mod is SLIGHTLY different
    MX36 LCA's, RA60 PS arms, RA60 struts with MA61 hubs, calipers, disks going into a corolla
    That should be fairly awsome. So with the MX36 LCA's you would have a bit of camber dailed in?
    they are 30mm longer than the factory arms on the corolla, i think MA61's are 300mm too so they would be an upgrade for them as well. I don't think i will get too much negative camber, but if i want more i can go to MX62 arms.
    Basically they are the same as the Sigma arm setup, and you get a choice of +30mm or +50-60mm if you wanna go to MX62 LCA's You need the steering arms reamed out or need to use factory MA61 steering arms if you wanna do this though.
    Awsome work. I've just finished doing this to my MA61 but with Sigma arms. I used PS Celica arms but used RA40 tie rod ends and the connecting rods to give me the extra 30mm each side. Works perfectly. Took her out for its first drive tonight and it seems all good. Wheel allignment coming up on wensday and then a few corners to see the improvements.
    Rosewood
    do you have any pictures of the new arms? as i want to do similar to my hilux steering setup.
