either a 4.1 or 4.3 going by thoes revs
Car is coverted to 1JZ with R154.. Recently blew the standard diff and have decided on a TRD 2-way.
Is a daily driver. Would like to sit around 3300-3500rpm at 110![]()
Anyone know the standard ratio off hand?
Being a G powered car any diff is likely.
Going by those revs and assuming stock tyres you are running around a 4.5-4.8 : 1 diff.
The plate on the firewall will tell you the factory diff, assuming its still in there.
Be careful ordering a new diff, as some GX71's had G series diffs, where as most had F series.
Ok thankyou.
Running low profile 15 inch tyres..
So just to make sure, 4.1 is going to give a higher speed at given revs compared to a 4.3?
Correct .
Hope this is the right code.
A42DL T292
T292
Povo spec T-series diff.
Stock ratio is 4.1:1
Is it worth looking for a centre, or should we be looking for a new housing?
Diff is really to small to put any decent amount of power through it.
But an F-series diff won't bolt up to your crossmember.
Try and source an F-series diff/crossmember from an MX73 Cressida and see if that bolts in.
